Quantcast Audio Sounds Too Slow? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Audio Conversion
06-08-2004, 02:11 PM
glent2k3 glent2k3 is offline
Send a message via MSN to glent2k3
I just finshed encoding 22 episodes of simpsons with Mencodeme
target was 352x576 @ 25 ....Problem is the orignals where 29.970 so when i did the audio the sounds is too slow. I thought they were 23.976 D'OH! any way i can fix these with out rencoding the video.Im currently testing goldwaves time warp fuction but this seems to be a slow process.Any suggestions would be aprreciated
__________________
put your liteon dvdr in the bin and buy an NEC 2500A
Site Staff / Ad Manager
06-08-2004, 03:26 PM
Dialhot Dialhot is offline
The diff is too big (20%) and there is no hope to fix that now...
06-09-2004, 01:23 AM
thnx phil yeah your right.loads of encoding to do
__________________
06-09-2004, 02:41 AM
Roc Roc is offline
is it realy 29.97 FPS?
Or is it 3:2 pulldowned / telecined material..
if yes, you have to "inverse telecine" it to get back the original 23.976 fps.
and speedup it by ~one Frame to 25fps.
The Audio track you can speedup with the BeSweet function NTSC2PAL..
A german tutorial for tmpgenc and/or Avisynth you can find here:
http://home.t-online.de/home/vcdhilf...s_ntsc2pal.htm
Good Luck
06-09-2004, 03:12 AM
Man... Simpson... a cartoon... designed for Television. How many are the chances that was shouted in 24 fps and telecined to 30 ?
BeSweet: How can I slow down the audio? canon Audio Conversion 9 01-21-2004 06:03 AM
audio sounds like chipmunks? kqmaverick Video Encoding and Conversion 5 12-13-2003 04:14 PM
VirtualDub: horrible clicking sounds in audio mpierce Video Encoding and Conversion 1 04-08-2003 07:44 AM
KVCD: audio sounds like it is lagging? Raynaldo Video Encoding and Conversion 3 01-30-2003 11:51 PM
KVCD: jerky motion, audio unsyncronized, slow frames? Neo Video Encoding and Conversion 0 06-11-2002 05:06 PM
All times are GMT -5. The time now is 01:12 PM  —  vBulletin © Jelsoft Enterprises Ltd
