06-11-2004, 05:16 AM
headache is not working proerly, i downloaded the files from dark.av
Headache is failing to load properly, i checked the log and nothing has loaded (vorbis, MP2enc etc) even though i extracted all the files in the same directory. i thought it could be that iv downloaded the wrong files.... so what i did was i downloaded them all and still no luck.i know someone else has had this problem as iv read it before but cant find the post. so please help me
Site Staff / Ad Manager
06-11-2004, 08:07 AM
Did you download the correct dlls. according to the CPU Type u got ??
06-11-2004, 08:14 AM
yep, i did that, i have an Athlon XP. so i downloaded the correct files according to this, it didnt work. so what i didthen is i tried them all for all the different processors.... it still didnt work.
wht do i do?
do u think there may be some errors on the files themselves? i donloaded from the actual site darkav.de.vu
06-11-2004, 09:49 AM
post the log (copy & paste)
06-11-2004, 09:59 AM
HeadAC3he v0.23a by Dark Avenger 12.07.2002
Loading azid.dll 1.8 build 825...succeeded
Loading ssrc.dll...failed
Loading lame_enc.dll...failed
Loading vorbis.dll...failed
Loading MP2enc.dll...failed
Loading MPAlib.dll...failed
Parsing INI-file...done
Notes:
dumb mode: uses absolutely no temp space
float mode: (much) faster, but uses destfile
as temp space on first pass
Choose appropriate target
and press Options 2 times for configuration.
If you experience instant crashes, try the MMX dlls.
06-11-2004, 11:18 AM
06-11-2004, 03:28 PM
Phil iv tried them all... the MMX old pentium, Athlon XP PENTIUM 3, pentium 4. What can i do? i really do think there is a problem with the downloads from the site
06-11-2004, 03:41 PM
Post a listing of your Headac3he folder using the directory listing command via DOS Console. So we can see what your HeadAC3he folder actually contains
06-11-2004, 04:53 PM
not sure how to do the dos command listing, but iv done a list of all the files below. everytime i open headac3he it shows this error
'The application failed to start because libmmd.dll was not found. Re-installing the application may fix this program'
list of files in my headac3he directory:
azid.dll
azidlegal.txt
Copying
email.txt
future.txt
headac3he.exe
knownissues.txt
lame_enc.dll
lamemod.txt
legal.txt
Licence
mp2enc.dll
mpalib.dll
ptb.exe
ptb.txt
readme
readme.txt
readmedll.txt
ssrc.dll
ssrclegal.txt
vorbis.dll
whatsnew.txt
headac3he.ini
06-11-2004, 06:06 PM
You didnt mentioned it before! So where's that libmmd.dll ????
If NOT provide with the application then search on google for dlldownload or so similair wher you can get a lot of dlls.
06-11-2004, 06:11 PM
yep that error comes up all the time. its not contained in the zipp i got from darkav.de.vu, i just thought its a file that doesnt make much of a difference since the other files didnt load. what does this file do???
il try the search
thanks mate
06-11-2004, 06:22 PM
@ khusru
stop to search.
just click in the "email" in my post, send me your mail and i send to you all versions full and with the new HeadAC3he024a10 with AC3 and AAC suport! then you can only unzip and choose what version works in your system! end of problems, ok?
06-12-2004, 06:29 AM
oh my god. u can download the dll file from darka. i cant believe they dont give it in the same directory as headache and u have to get separatly.
that fixed it striaght away, iv had this problem for so long but didnt bother looking in to it cos i started using besweet.
thanks u guys, always helping. and dont worry about the files jorel mate
All times are GMT -5. The time now is 10:10 PM — vBulletin © Jelsoft Enterprises Ltd
