Quantcast Help with Picking the Best Audio Converter - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Audio Conversion
06-12-2004, 07:32 PM
trigger911 trigger911 is offline
Send a message via AIM to trigger911 Send a message via Yahoo to trigger911
whatz the best app to extact audio from a vob and to multiplex with tmpenc?
Site Staff / Ad Manager
06-12-2004, 07:33 PM
Dialhot Dialhot is offline
DVD2AVI.
AND DO NOT USE TMPGENC TO ENCODE THE AUDIO
06-12-2004, 07:34 PM
i know im not that lazy i learned for my evil lazy ways =)
06-12-2004, 07:36 PM
It was just to be sure you won't forget
06-13-2004, 05:44 PM
hehe seemed like ur realy pushing that idea that tmpeng sux0rz sooo i turst u seem to be educated more on this but i got dvd2avi but how the heck do i pull the sound with it i go the latist ver off the ysite yesterday i had to leave they house yesterday and i just got back today but i cant wait to get these vobs off my pc because im soooooo tired of a Beep & balllon popin up saying im out of space.
06-13-2004, 06:31 PM
Be carrefull. Do NOT use the latest release but rest on the old good 1.76 version !
To demux audio you just have to go in the audio menu and select "demux all track". Then the audio streams will be demuxed while you are producing the d2v project. (you know how dvd2avi works ?).
06-13-2004, 09:48 PM
I've used it when i first started doing vcds to run the video+audio thru tmpenc i dont rember too well thats been like 2+ years ago
ps i got the 1.77.3 ver it suxors crashes real bad and horrible gettin oldie
PSS went back to site cant find the ol good one any ideas?
psss found it i pick i save the d2v then run the d2v thru Tmpgenc right? or there another step? thats how i used to use it.
well i tryed to run the d2v thru Besweet some ay i dont see how? But i got a plus tho i dont have to do each vob as 1 video file i can use it to link all the vobs toghter
06-14-2004, 03:40 AM
Ipsss found it i pick i save the d2v then run the d2v thru Tmpgenc right? or there another step? thats how i used to use it.
It would be far better to use an avisynth script but if you don't want to bother yourself with this new "difficulty", just use the d2v as source in tmpgenc.
NO
Look at besides the d2v file : you will find all the ac3 files corresponding to the audio tracks of your DVD.
06-14-2004, 05:19 PM
btw i love to learn new stuff education is power u know rember the coin op of mortal kombat haha
well with the avisynth i have it installed for both 2.53 and 3 sooo i whanted to learn how to use that app and good site for a tut i never did know how to use it. so im ready to go that way do i need another app for it or what? all i got is the tmpgenc input support.
06-19-2004, 12:43 PM
well i figured out that dvd2avi exported the *.ac3 lol i ran it thru besweet with the dvd2avi checkmark and boom all fixed all synced again lol i didnt know that dvd2avi left a 104ms silance in it but thanx for the help DailHot
PS I told u the easy stuff is where i always get stuck i figured that out when i was drunk going thru folders lol
07-01-2004, 03:20 PM
well i was wronge i thought it was in-sync but it wasnt i been trying for a week to get this right im having sooooo much trouble is there another way i can do this im soooo confused
but thanx alot of the help i did get alot better quility video but the audio is where i have troubles
07-05-2004, 09:39 AM
Fluffbutt Fluffbutt is offline
Dialhot, I've had nothing but trouble when multiplexing with tmpgenc..
I switched to bbmpeg, and all the problems disappeared!
__________________
Meeow!
07-05-2004, 09:45 AM
Trouble to read the mpeg on your standalone or trouble to do the muxing by itself ?
First possibility can be real (depend on the standalone) but second one means... ugh... let say that you just misuse the tool
07-05-2004, 12:31 PM
When I multiplexed with tmpg, the reulting mpg (to vcd via vcdeasy) plays on the stand alone, but there's a 1/4 sec pause about every 4 secs.
I tried all sorts of things to fix it, thinking it was something to do with the audio, or the multiplex rate (I can't see where to change that in tmpgenc..)
At anyrate, I changed to bbmpeg, used Kwags settings he posted on this forum (his picture of the settings), and have ahd zero problems on the standalone..
Thanks.
__________________
Meeow!
07-05-2004, 02:35 PM
Okay, standalone problem so. That's not the first time. But some have problems to with bbmpeg . The only diff is that in bbmpeg you can change the "force muxrate" parameter and that solves the problem.
Bingo
07-06-2004, 02:17 AM
Dialhot - you've got the answer!.
Tmpg works well on files that are generally low bitrate, or don't have bitrate spikes.
Tmpg worked on a few of my kvcd's - but lately I have to cut 10 mins off the start, write it to a cdrw, see if it plays. If so, then write the full mpg to cdr, if not go back and remux with bbmpeg.
I might as well just stick to bbmpeg for muxing - it's not failed me yet.
Thanks for your replies - different thoughts/views are important!
__________________
Meeow!
07-10-2004, 11:20 PM
hello fluffbutt
im gonna try bbmpg see if it helps any if not any one ealse has ideas or knows better appz please share
thnax a lot
-Trigger911
Converter audio MP2 para AC3 (2.0 e 5.1) latsilva Conversão e Codificação de Vídeo (Português) 8 07-16-2004 09:34 PM
Porque não converter o audio junto com o Video no TMPGEnc? Alex_Matrix Conversão e Codificação de Vídeo (Português) 3 04-10-2004 02:12 PM
Como converter o audio de 29.970 para 23.976 Raivos Conversão e Codificação de Vídeo (Português) 0 01-13-2004 09:39 PM
Converter 24.002 -> 23.976 JonhyBoy Conversão e Codificação de Vídeo (Português) 2 01-13-2004 01:31 PM
Picking a Laptop to play KVCD movies black prince Computers 3 01-16-2003 01:34 PM
All times are GMT -5. The time now is 07:02 AM  —  vBulletin © Jelsoft Enterprises Ltd
