Quantcast TMPGEnc DVD Author does Not Create a Main Menu? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Authoring VCD, DVD, Blu-ray
06-13-2004, 05:59 PM
bigggt bigggt is offline
OK first time using so probably stupid mistake but
I put 2 movies on a dvd and in the authoring program i had selected 2 tracks and the main menu
I can't figure out how to get to the main menu because when i pop the dvd in the player it justs plays the first movie which is OK but with my one dvd player Cyberhome 300 i can't even get to the second track
any ideas
Site Staff / Ad Manager
06-13-2004, 06:27 PM
Dialhot Dialhot is offline
I don't have tmpgenc author installed at the moment on my PC but I remember that there is a combo box where you can choose the default behaviour of the DVD once played in the standalone. By default it is set to "play first track" but you can set it to "display main menu".
I think this is on the menu design window.
06-13-2004, 07:33 PM
Thanx Phil
I see it and will try it with my next dvd
Authoring with TMPGEnc Author without Menu? nicksteel Authoring VCD, DVD, Blu-ray 0 11-17-2003 11:54 AM
DVD2SVCD: Let's create a menu plugin for DVD2SVCD azel Video Encoding and Conversion 1 09-13-2003 11:40 AM
program to create a fully functional menu for vcd? andybno1 Authoring VCD, DVD, Blu-ray 6 11-18-2002 05:24 PM
Create Menu Page using VCD easy? wpeter01 Authoring VCD, DVD, Blu-ray 3 10-20-2002 02:16 AM
How to create SVCD menu with a moving select button? muaddib Authoring VCD, DVD, Blu-ray 0 07-24-2002 08:21 PM
All times are GMT -5. The time now is 12:49 PM  —  vBulletin © Jelsoft Enterprises Ltd
