Quantcast Nokia9600 Receiver with Dvb2000 Recorder? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Video Capturing / Recording
08-31-2002, 09:53 AM
cbr900 cbr900 is offline
which resluation should I capture the video for kvcd3?
and the output file is in .mpg format how to use it with dvd2avi and fitcd?
Site Staff / Ad Manager
08-31-2002, 10:05 AM
kwag kwag is offline
What resolution does your dvb2000 recorder supply?
-kwag
08-31-2002, 10:54 AM
it depends on the channels resolution......It can record in all avalible channels formats.
the player can not change the resolution of the channels.
720x576, 704x576, 352x576.........
all of them.
08-31-2002, 12:42 PM
I'm sorry, I asked the question incorrectly. What is the output resolution from your receiver? What is the resolution being transmitted from your satellite provider?.
-kwag
08-31-2002, 02:56 PM
***What is the output resolution from your receiver?***
It depends on the channel itself. The format is transmitted from the broadcaster....and I just get what they transmit.
like, MTV is on 528x576 and 25fps on nilesat on 11861V frequency.
I can not change that with my receiver.
08-31-2002, 03:53 PM
Well, in that example, your best capturing resolution is indeed the same as the one used on the x3, which is 528x576
So capture at that resolution, and encode with the x3.
-kwag
DVRs: what features should be present on the receiver box? rds_correia Players, DVRs, Media Centers 6 02-27-2006 10:02 AM
DVD Recorder de Mesa Cyberlab Conversão e Codificação de Vídeo (Português) 2 10-31-2004 09:39 PM
HeadAC3he: Good Pro-Logic II Receiver? Jellygoose Audio Conversion 5 06-18-2003 04:02 AM
DVD2AVI: How to dvd2avi with .mpg files captured from nokia9600? cbr900 Video Encoding and Conversion 0 08-31-2002 09:21 AM
New Panasonic DVD Recorder Bud Players, DVRs, Media Centers 1 06-27-2002 02:03 AM
All times are GMT -5. The time now is 12:23 PM  —  vBulletin © Jelsoft Enterprises Ltd
