Quantcast Final Capture Script for Avisynth 2.5? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Video Capturing / Recording
08-04-2004, 08:47 AM
jscorrea jscorrea is offline
Send a message via ICQ to jscorrea
Hello,
The tutorial of Incredible is very good. But I was with doubt in relation to script for the Avisynth. Has one script complete for version 2.5?
Details:
Video with 1h:38min - SIZE 28GB
Captured with IUVCR in a PIXELVIEW CARD
640*480 resolution MJPEG v 3.0.0.9
5 dropped frames
Deinterlace filter used
I will use this script with CCE and TMPEGenc.
Thanks,
JS
__________________
JSCORREA
Site Staff / Ad Manager
08-04-2004, 09:20 AM
incredible incredible is offline
Send a message via ICQ to incredible
As you capture in 640x480 I do assume you live in NTSC Land.
And that means NO DEINTERLACING while capturing!!!
Because your Movie captures just will be telecined which can be reversed by an inverse telecine process via Avisynth, means, you wont end up in ugly blended capture results!
Telecide().Decimate()
... as also mentioned in my guide, so do look out for neuron's decomb package at avisynth.org and get the right parameters out of the readme file.
Related to a script ....
.... as every capture is unique, theres no optimal capture script. A script bases on source noise, PAL or NTSC, Color/Luma State and many other things, so you have to test on your own to get a feeling for that.
08-04-2004, 09:28 AM
Thanks for tips ...
__________________
JSCORREA
08-04-2004, 09:35 AM
This one also doesn't hurt:
http://www.doom9.org/index.html?/capture/start.html
Avisynth: Optimal KVCD script for PAL DV Capture narc60 Avisynth Scripting 0 03-17-2006 01:53 PM
Avisynth: A script to enlarge video final size? Prodater64 Avisynth Scripting 5 08-07-2005 02:30 PM
Avisynth: VHS and Capture script? Bilal Avisynth Scripting 30 08-26-2003 04:25 AM
Avisynth 2.5 capture script?? andybno1 Avisynth Scripting 2 07-27-2003 10:35 AM
Avisynth: Optimal Avs script for analog capture? Sergeiv Avisynth Scripting 6 04-11-2003 04:27 AM
All times are GMT -5. The time now is 01:35 AM  —  vBulletin © Jelsoft Enterprises Ltd
