Quantcast Which Capture Program Under Windows XP? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Video Capturing / Recording
09-16-2002, 11:34 AM
Virtual7 Virtual7 is offline
Hello,
I'm using Windows XP Pro with an Hauppauge WinTV capture card. I've installed the latest WDM drivers from Hauppauge. I would like to capture from a satellite source. As mentioned in the FAQ:
"...If you are capturing from a VHS tape or TV ( Satellite, etc. ), you capture at 352x480, not at 352x240. This way you get both fields..."
Ok, my goal is to capture at 352x480 (NTSC) with the HuffYUY codec and then convert to xVCD. I know most people use VirtualDub but this program is based on Video-For-Windows technology. Under Windows XP, VirtualDub uses the Microsoft WDM-to-VFW wrapper. And this wrapper only allows capture resolution of up to 320x240. I think that VirtualDub 2 will support WDM drivers. I've read a lot about the subject and people suggest to use a Direct-Show capture program.
Which Direct-Show capture program should I use? I've already tried iuVCR and it has problems with the HuffYUY codec.
Thanks,
Virtual7
Site Staff / Ad Manager
09-16-2002, 11:46 AM
kwag kwag is offline
Hi Virtual7,
Go here: http://btwincap.sourceforge.net
Download their drivers. Now you can cap at just about any resolution and frame rate you want. Will work just fine with Vdub.
-kwag
09-17-2002, 08:13 AM
Thanks Kwag!
I've tried the btwincap drivers and they allowed VirtualDub to capture at any resolution! Now I'm gonna use VirtualDub Sync.
Virtual7
FastStone Capture - Very good Free Capture Tool sparskter Computers 0 08-28-2006 01:14 PM
Playback problems - Windows XP and Windows Media Player el_mero_zooter Authoring VCD, DVD, Blu-ray 4 04-17-2003 01:11 PM
KVCD: Capture to .wmv using Windows Movie Maker? GMan Video Capturing / Recording 13 03-06-2003 08:57 AM
Recording Video: No capture under Windows 2000 jocomo Video Capturing / Recording 3 02-21-2003 10:37 AM
Best video Capture Program? andybno1 Video Capturing / Recording 16 09-29-2002 09:51 AM
All times are GMT -5. The time now is 03:08 AM  —  vBulletin © Jelsoft Enterprises Ltd
