Quantcast Jerky Playback on Standalone DVD Player? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Hardware and Technology Forums > Players, DVRs, Media Centers
10-10-2004, 05:18 AM
tyler5 tyler5 is offline
i've encoded a avi file to kdvd. everything went successfully. i then burned it to watch in on my standalone only to discover that it freezes every 30 seconds or so. the playback is not smooth. what should i do? it plays fine when previewing my project in tmpgenc and also with powerdvd. i have a lg 6053 standalone. btw, i've downloaded samples of kvcd/kdvd from emule and all of them work flawlessly.
Site Staff / Ad Manager
10-10-2004, 10:30 AM
rds_correia rds_correia is offline
Then you're lucky and the only thing wrong is in your encoding methods
Can you please describe them here:
- tools used and their release versions
- which guides followed
- etc.
Please read the forum rules and the Disclaimer.
If you don't help us (by giving us more info) we can't help you.
Cheers
__________________
Rui
10-10-2004, 12:04 PM
Mental Mental is offline
Dumb question but did you check the framerate of your source material compared with your finished result?
Converting from one framerate to another can often cause problems like you describe, I had the same problem and ended up solving it by feeding an avisynth script to FreeEnc which uses the AssumeFPS command to force the framerate to be what ever I want.
__________________
Dave
10-10-2004, 12:32 PM
the framerate of the original file was 23.976, kdvd encoded it to 29.97 (23.976 (internally 29.97fps)).
10-10-2004, 01:32 PM
The tools and methods used please, otherwise it's almost impossible to help.
Shall we imagine what you did?
There are plenty of different tools, plenty of different methods and plenty of different guides/explanations.
__________________
Rui
Jerky playback on my standalone DVD player? tyler5 Video Encoding and Conversion 1 02-03-2004 03:10 PM
avi to kvcd has Jerky playback? toxicpoison Video Encoding and Conversion 16 12-31-2003 01:39 PM
KVCD: Jerky playback? starclone Video Encoding and Conversion 1 09-26-2003 03:27 AM
KVCD: What can cause jerky playback? jshew Video Encoding and Conversion 10 04-17-2003 04:47 PM
Jerky VCD Playback? miksmith Players, DVRs, Media Centers 24 02-03-2003 01:45 PM
All times are GMT -5. The time now is 05:48 AM  —  vBulletin © Jelsoft Enterprises Ltd
