Quantcast DVD Burner: DVD+RW Direct on-Disc Editing - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Hardware and Technology Forums > Blank Media / Burning Discs
10-11-2004, 03:24 PM
Hydeus Hydeus is offline
Hello.
I'm pretty green in this, so I need advice
I know that this function is available with recorded DVD video discs, but how about to edit the same way DVD+RW with data (egz. for backuping important data, without erasing whole disc). On CDrw this is possible with UDF, so how to do this with DVD+RW Some way, some tool, some UDF
Thx 4 advice.
EDIT: I got NEC 3500, and this isn't support Mt.Rainer bu hardware (or firmware) so can I do this by some application
__________________
Go for SECAM =)
Site Staff / Ad Manager
10-12-2004, 03:30 AM
Dialhot Dialhot is offline
I use Drang'n'Disc form Roxio that is the new name of DirectCD and can handle DVD. InCD from Nero was also adapted for the DVD.
In fact you are right when speaking about UDF tools because that is the same protocolthat is used. The only diff : no need to format the media, that means no time nor space lost
Easy Way to CONVERT two-DISc VCD/SVCD TO one-DISc KVCD? DerekBarton Video Encoding and Conversion 5 09-17-2003 11:05 PM
KVCD Guide: Encoding/transcoding a 2-Disc SVCD to a single disc Avalon Video Encoding and Conversion 11 08-14-2003 05:02 PM
NEC DVD burner, disc could not be closed syk2c11 Blank Media / Burning Discs 7 07-09-2003 09:37 AM
Recording Video: Direct DVD editing ? noize Video Capturing / Recording 4 02-11-2003 03:52 PM
Has anyone ever captured direct to KVCD? digitalvideo Video Capturing / Recording 1 06-20-2002 05:29 PM
All times are GMT -5. The time now is 03:55 AM  —  vBulletin © Jelsoft Enterprises Ltd
