Quantcast Programming: Any Courses in Purebasic Available? - digitalFAQ.com Forums [Archives]
11-10-2004, 06:49 PM
danpos danpos is offline
Hello, Kwag ! I do know that you are a expert in PureBasic. I´m going to begin in that language (a long time ago I did coding with Basic for TRS-80 ) and I would like to know if you can point out to me some course about that language, because documentation about one is very poor!
Cheers,
Site Staff / Ad Manager
11-10-2004, 07:54 PM
kwag kwag is offline
Hi Danilo ,
Well, I'm not really an expert on PB, but I can get around it
One good source is this:
http://www.xs4all.nl/~bluez/datatalk/pure1.htm
And also check this: http://www.purearea.net/pb/english/links.htm
And mind you, Pure Basic is nothing, not even close to Basic for TRS-80
It's a full structured language, wich resembles Basic in it's syntax, but it's as powerfull as C, because it has full structures, unions, you can work at the bits level, full inline assembly language support, and the full Win32 API callable from within the language
-kwag
11-10-2004, 08:25 PM
@Kwag
As I said before, "You are the man !"
Thanks so much for the links. So, let it go to school !
Cheers,
11-11-2004, 04:53 AM
incredible incredible is offline
Send a message via ICQ to incredible
If you first generate a little Window-Interface in the visual editor and save the source you easely see the logic of how things work.
Then you also will have a look at the help section where all commands are explained. After this you look at purearea.net where you will find many sources for severaly purposes. Do look in these codes and you also here will easely find the logic of purebasics concept/syntax.
2 Days and you will have your first little application if you already have some tiny skills in Basic
Programming: PureBasic v4.0 beta released incredible Avisynth Scripting 3 02-08-2006 07:49 AM
Programming: PureBasic 3.94 released rds_correia Avisynth Scripting 4 09-22-2005 03:09 AM
Programming: Purebasic 3.92 has been released rds_correia Avisynth Scripting 4 01-31-2005 06:17 PM
Programming: PureBasic looks like a must-buy Zyphon Avisynth Scripting 20 05-06-2004 09:00 AM
Programming: PureBasic webbrowser rds_correia Avisynth Scripting 12 04-21-2004 04:08 AM
All times are GMT -5. The time now is 12:57 PM  —  vBulletin © Jelsoft Enterprises Ltd
