Quantcast ATI TV Wonder / Btwincap Drivers - No Sound? - digitalFAQ.com Forums [Archives]
10-08-2002, 12:59 PM
TKS TKS is offline
Ive installed the drivers correctly as far as i know on my ATI Tv wonder/win2k system, and i can capture video very well, but for the life of me cant figure out why i have no sound.... Has anyone else had this problem?
tks
Site Staff / Ad Manager
10-08-2002, 02:33 PM
NYPlayer NYPlayer is offline
you have to use the _windows_ volume levels. either from control panel/sound/advanced or double click the yellow speaker in the tray. do properties/options and select 'recording'. check the one you want to record from preferably line in.
10-08-2002, 04:56 PM
TKS TKS is offline
Well i screwed around with that a bit, but ill do a bit more fiddling and see whats up...
Id really like to get this drivers working
Anyone know of some good advice for Huffy settings? Ive been just using the defaults...
tks
10-08-2002, 06:01 PM
TKS TKS is offline
I got it working but not from fooling around with the sound settings... i just got the newest version of the drivers.. i had been using an old version before.. So thats good...
Umm is 550 megs a minute a good compression ratio for full screen 29.9 fps?
tks
10-08-2002, 09:08 PM
twobit326 twobit326 is offline
Send a message via AIM to twobit326
Um, do you have the cable going from out of your Cap card to your line-in? Also, make sure that line-in is set as what you're recording from.
-Twobit326-
10-09-2002, 11:56 AM
TKS TKS is offline
I got it
THanks.....
tks
VCDEasy - correct drivers loaded for CD Burning? Shibblet Authoring VCD, DVD, Blu-ray 3 06-19-2005 10:42 AM
Drivers, Resolução e Desentrelaçar de capturas Braxton Conversão e Codificação de Vídeo (Português) 86 08-16-2004 03:19 AM
Drivers p/ Placa de Captura. corsineto Conversão e Codificação de Vídeo (Português) 1 06-02-2004 03:38 AM
Will OS work without drivers for hardware ak47 Computers 1 09-06-2003 12:56 PM
BTWincap drivers - tv tuner type? twobit326 Video Capturing / Recording 0 10-11-2002 05:12 PM
All times are GMT -5. The time now is 09:52 PM  —  vBulletin © Jelsoft Enterprises Ltd
