Quantcast Compiling Mencoder - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Avisynth Scripting
11-29-2004, 09:59 PM
Prodater64 Prodater64 is offline
Hi: I already have a CVS synch in my HD, Cygwin and MSYS.
How to compile it for W32.
I have not idea.
Site Staff / Ad Manager
11-30-2004, 12:39 AM
fabrice fabrice is offline
Hi Prodater,
to compile mencoder, you only to execute 2 things from mplayer root directory:
- execute "configure --enable-largefiles --enable-static --enable-win32 --enable-dshow" to configure the compilation
- execute "make mencoder" to compile mencoder
If you compile it with mingw, you can execute it from msys shell (because of \ to / translation). If you compile with cygwin, you can execute it directly from windows.
Salu2
Fabrice
11-30-2004, 04:32 AM
First try, before your previous post, without that options, only --enable-largefiles, gives me 2 exes very much smaller that official pack. stdout show me a lot of no options.
How can obtain same version as original more toolame option enabled.
It says autodetect, but is seems that not.
11-30-2004, 04:51 AM
Dialhot Dialhot is offline
I guess taht the smaller size is due to the lack of "--enable-static" (you are using dynamic loading of the dll insteed of static linking within the exe).
For lame... perhaps you need to have the -enable-dshow to have all the option avalaible ?
11-30-2004, 02:02 PM
Hi,
I agree with Phil: exe size can be smaller because of dynamic binding.
For toolame stuff, just have a look at configure, to see what option there is (sorry but I don't have any mencoder source here...).
Salu2
Fabrice
EDIT:
watched teh CVS image, and I found this options in configure:
--disable-toolame disable Toolame (MPEG layer 2 audio) support in mencoder [autodetect]
--with-toolamedir=DIR path to Toolame library and include file
This mean that if you have the toolame library and include file, you can compile mencoder with toolame support
Mencoder: Can be the 60fps to 25fps conversion done within mencoder? digitall.doc Video Encoding and Conversion 4 06-15-2004 02:21 PM
Mencoder: Changing/Setting field order in mencoder tuco1979 Video Encoding and Conversion 1 04-17-2004 09:06 AM
Mencoder: Optimal Script with mencoder filters vmesquita Video Encoding and Conversion 38 04-14-2004 09:55 AM
Mencoder: Problems compiling Mplayer/Mencoder rds_correia Video Encoding and Conversion 6 03-18-2004 09:11 AM
Compiling a 'best of' DVD-R Scav Authoring VCD, DVD, Blu-ray 1 05-03-2002 12:01 PM
All times are GMT -5. The time now is 11:03 PM  —  vBulletin © Jelsoft Enterprises Ltd
