Quantcast Okay to Burn KDVDs in Pioneer DVD Burner? - digitalFAQ.com Forums [Archives]
02-20-2005, 05:17 AM
WOWIEGURL WOWIEGURL is offline
Send a message via ICQ to WOWIEGURL
I'm planning to get a pioneer A-06 to start doing kdvds .. do I need to check if it is okay to burn kdvds? and where do I find a chart which will tel me that? its a 2nd hand model. THanks
Site Staff / Ad Manager
02-20-2005, 06:03 AM
rds_correia rds_correia is offline
As far as I am aware all DVD burners in the market can burn KDVDs.
As all CD burners can burn KVCDs
It's more a matter of which player you're using to play your KVCD/KDVD.
Just don't buy a cheap LG 4120B dual layer unit.
I've had 2 and I'm on my way to ask for a 3rd to replace another defective one.
I'm never buying LG burners again
Oh, make sure it can burn all the standards: CD-R/CD-RW/DVD-R/DVD-RW/DVD+R/DVD+RW and dual layer if you would like to have 9GB on a single disc.
Cheers
__________________
Rui
02-20-2005, 10:19 AM
Dialhot Dialhot is offline
I have pionner 106D (oem version of A06) and it is very nice for KDVD.
But it is a very old 4x model. You have the 107D that is 8x now and even the 109D that is DL.
Nero Burner will not Burn to CD Drive! Toon Authoring VCD, DVD, Blu-ray 2 03-21-2004 08:02 PM
How to overburn in CD-r mode if using a Pioneer DVD Burner! incredible Blank Media / Burning Discs 0 03-17-2004 05:58 AM
Buying a DVD Burner tomorrow for the first time. Pioneer A06 audi2honda Blank Media / Burning Discs 6 12-15-2003 07:18 PM
How to burn dvd without dvd-r burner ? The Neta Authoring VCD, DVD, Blu-ray 1 12-04-2003 11:27 AM
DVD Burner from Pioneer, but haven't been able to copy anything? eroque Video Encoding and Conversion 9 01-26-2003 04:34 PM
All times are GMT -5. The time now is 10:19 AM  —  vBulletin © Jelsoft Enterprises Ltd
