Quantcast Avisynth: CCE Settings? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Avisynth Scripting
06-03-2005, 07:32 PM
khusru khusru is offline
i didnt know where else to put this message so sorry to mods.
i am using avisynth and just started using CCE to encode with, can some one tell me where the option is to encode progressive, i am doing pal 25 fps but cant find the progressive option, all i can see are just the pulled down options
thanks in advance
Site Staff / Ad Manager
06-05-2005, 02:33 AM
clickit clickit is offline
which CCE version are you using ?
in latest version, i think that is the 2.70.02.01, you must press the "picture quality" button in settings page and there is a progressive check-box at bottom
__________________
it's one thing that i know for sure, that i know nothing for sure
06-05-2005, 07:29 AM
im using the latest version. should i check any of the pull down boxes as well because one of the options has to be checked
06-05-2005, 02:49 PM
Dialhot Dialhot is offline
Pulldown checkbox are meaningless when encoding in PAL. So don't worry about wich one is checked, CCE won't use it.
06-05-2005, 09:22 PM
thanks for the help guys
KVCD AviSynth GripCrop() settings? Brenth Avisynth Scripting 4 08-08-2008 11:42 AM
Best avisynth settings for avi to svcd? pixeldotz Avisynth Scripting 0 07-27-2003 12:58 PM
Avisynth: Dgbob settings? jorel Avisynth Scripting 17 07-27-2003 09:47 AM
Avisynth: Any great new settings for Animation? LadyMiles Avisynth Scripting 20 12-23-2002 09:00 PM
Avisynth: Script Settings for VRO files? Bud Avisynth Scripting 1 06-01-2002 09:07 PM
All times are GMT -5. The time now is 12:34 AM  —  vBulletin © Jelsoft Enterprises Ltd
