Quantcast Cross-Fade or Blend MP3 File? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Audio Conversion
07-10-2005, 10:50 PM
black prince black prince is offline
@Anyone,
I've used Nero Express to cross-fade or blend my mp3's created from
EAC using LAME encoder. Nero would not perfrom the cross-fade beacuse
it said my CDRW burner didn't support it I like the sound of
continous music without silence gaps. If anyone has used a software
program that will do this, please share.
-BP
Site Staff / Ad Manager
07-10-2005, 10:58 PM
kwag kwag is offline
Your CD burner doesn't support gapless tracks
-kwag
07-11-2005, 03:01 AM
Zyphon Zyphon is offline
@BP
How old is your burner as most modern burners to my knowledge have supported gapless recording for ages now.
__________________
Regards.
Michael.
07-11-2005, 09:16 AM
Kwag,
Just purchased it new four months ago It's a CDWRITER 5232. I have
My Mix software and it says it can blend, but the output won't save
the cross-fade results. WOW This is frustrating. Also, it
seems that EAC using LAME creates silent frames as part of the MP3
conversion which is added to the audio file. I noticed the play times
between the original CDA and the MP3 have increased. Example from
28 seconds to 32 seconds. There must be a way to automate removing
silent gaps, fade-in and fade-out for each song without doing this
manually.
-BP
07-11-2005, 10:11 AM
I know that Nero Express has an option to 'remove the silence at the end of *.cda tracks' I don't know if this works with wav or mp3's though.
It says that audio is stored in frames and the audio might not end exactly on the end of a frame so this removes the silence at the end of the frame.
__________________
Regards.
Michael.
07-13-2005, 02:40 PM
@update,
Just tried FooBar2000 v 0.8.3 with a plugin foo_dsp_continuator.dll and
Huston we have crossfade. SWEEEEEETT If anyone knows how
to save this to a WAV file PLease help!!!
-BP
07-13-2005, 08:02 PM
@anyone,
@update,
Huston we have crossfade. Smile SWEEEEEETT Cool If anyone knows how
to save this to a WAV file PLease help!!! Smile
-BP
I added plugins (1) foo_burninate.dll and (2) foo_diskwriter.dll
and burned my first music CD using crossfade with fade-in and
fade-out. WOW!! It's fantastic!!
-BP
07-14-2005, 04:55 AM
Thanks for the info BP I may even give this foobar a test myself.
__________________
Regards.
Michael.
07-14-2005, 05:24 AM
Hi BP,
Which package did you install the 'Special' one?
Also are the above plugins in the Special package?
__________________
Regards.
Michael.
07-14-2005, 05:34 AM
@Zyphon,
I installed the "Special", but used the FULL installation instead of normal.
I also, downloaded the plugins from FooBar2000's website. There are
other plugins, but for now this is all I need. What a SWEEEETTT
program. I've burned a few more custom Audio CD's and they came
out fantastic.
Tip: After you highlite your mp3 songs in FooBar2000, use the right
click of your mouse and select Burn to CD. This will burn the songs
to your blank CD.
-BP
07-14-2005, 07:32 AM
@black prince
Thanks for the info and the tip I shall give it a try.
I am pleased your results sound so great.
__________________
Regards.
Michael.
07-31-2005, 06:27 AM
@Update,
I still use EAC + LAME as my music ripper and now I use MP3TAG as my
mp3 tag editor. I found foobar2000 not as stable with the crossfade
plugins and bought "MixMeister Pro 6" instead. I've been using the 30
day trialware version and liked it so much, I spent $50. It can burn
directly to CD and has mp3 catalog function similar to MP3CAT.
-BP
08-01-2005, 07:06 AM
Thanks for the update BP.
__________________
Regards.
Michael.
blend of interlaced-progressive material? ginoboy Video Encoding and Conversion 2 07-30-2004 05:12 PM
Fade In/ Fade Out no script: como? FlavioMetal Conversão e Codificação de Vídeo (Português) 6 07-21-2004 08:27 AM
Musik - an open-source, cross-platform multimedia player kwag Audio Conversion 0 05-05-2004 01:06 PM
TMPGEnc: simple fade out from an mpeg-1 file? TKS Video Encoding and Conversion 15 03-26-2003 12:34 PM
Avisynth: Fade in / fade out not working? TKS Avisynth Scripting 0 11-07-2002 10:20 PM
All times are GMT -5. The time now is 03:22 AM  —  vBulletin © Jelsoft Enterprises Ltd
