Quantcast DVD Subtitles with DVD-Lab Pro - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Subtitles
08-03-2005, 06:29 AM
Prodater64 Prodater64 is offline
DVD subtitles with DVD-lab PRO
a traslation of original BJ portuguese excelent guide.
We need:
SubRip: http://zuggy.wz.cz/
DVD-lab PRO: http://www.mediachance.com
Run SubRip. ClickVOB.
1. Click Abrir IFO.
If you already extracted subtitles VobSub or with VoSub subtitle ripper, select IDX created.
2. Select subtitles to extract.
3.Action, mark Subtitle -> BMP.
4. Click Start.
5. Mark Sonic DVD creator.
6. Select Custom colors and contrast
7. Select colors as defaults or try another ones (I always leave it as default).
7.1 Escolha Sonic DVD Creator.
8. Click OK.
Wait, extracting subtitles.
9. Click Output format -> Select format
10. Select Sonic Scenrist (*.sst)
11. Click Convert to format.
12. Click File > Save as.
Save as SST file in same folder as bitmaps.
Run DVD-Lab PRO.
Load audio and video.
13. In Movie window click SUB 1.
14. Click Import and open your SST.
15. Click first subtitle line to preview it no little screen at right side.
16. Unmark Zoom 1:1 option.
17. Do select what you want or leave it as default!
18 . Click Generate Subtitle Stream.
Site Staff / Ad Manager
08-03-2005, 06:41 AM
Dialhot Dialhot is offline
Isn't there a problem with BMP subtitles when you do a KDVD that is not in the same resolution than the original DVD one ?
Be carefull ! The problem is perhaps not noticiable if you use 704*576 but if en encode in 352*576, I wonder if DVDLabo Pro will resize the bitmap correctly or not
08-03-2005, 07:15 AM
I don't know it.
It deserves a test.
Not problem when I encoded 704*576 (until now always).
How to Add Subtitles on 3D movie? canon Subtitles 0 08-17-2009 12:59 PM
Subtitles: I need vsub23.dll Phunote Subtitles 3 09-21-2004 06:21 PM
Subtitles: Adding .srt subtitles to a KVCD movie xpronic Subtitles 13 06-12-2004 09:33 PM
How to know if dvd has subtitles? Adder Video Encoding and Conversion 14 05-02-2004 12:13 PM
Capturing VHS Subtitles? dredj Video Capturing / Recording 3 07-05-2003 11:10 PM
All times are GMT -5. The time now is 03:49 AM  —  vBulletin © Jelsoft Enterprises Ltd
