Quantcast Avisynth: Loading OGM Files? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Avisynth Scripting
10-05-2005, 08:50 AM
shgr shgr is offline
hello everyone
long time i have to deal with an ogm video. i remember having succeed but now i need help again.
when i load this script on tmpgenc, it starts encoding but just a black screen.
DirectshowSource("C:\video3divx5.ogm", fps=30.000)
BilinearResize(320, 190, 4, 0, 632, 352)
aSharp(2, 4)
AddBorders(16, 17, 16, 17)
TextSub("C:\video3.srt")
thank you so much
Site Staff / Ad Manager
10-05-2005, 12:00 PM
Dialhot Dialhot is offline
Are you sure you have the codec used for the video that is in the ogm ?
Let remember that ogm is just a container, not a codec. The video in the container can be xvid, divx or other thing.
Note: you can also open it into virtualdub mod and save it as avi. This will probably remove the audio but who cares ?
10-05-2005, 12:22 PM
thank u, Dialhot
yes, i know that ogm its just a container and i think i have the exact codecs because i can play it in the windows media player with no problems.
10-05-2005, 04:05 PM
That's definitely not an answer. BTW this time I did a mistake, this is not a codec that you miss but a directshow filter. Open Graphedit, drag your OGM into it and look at how your file is rendered. You will probably have an error there.
10-05-2005, 11:24 PM
well, i dont know what graphedit is for... but i loaded the file on it... and this is what i got
10-06-2005, 05:00 AM
No error in the rendering so you should have no problem.
1/ Try to go into the DirectVobSub configure panel, in the "General" tab, "Loading" section, select "Load when Needed".
2/ Go into the preview of tmpgenc (after load the avs, menu File -> Preview). Do you have a black screen there also ?
3/ Play the avs in a media player, what yo you have ?
4/ add a "Info()" at the end of the script and redo the point 2 and 3. What is the colorspace indicated on the video ?
Avisynth: Subtitle loading problem khusru Avisynth Scripting 2 01-25-2005 09:34 PM
Avisynth: Loading RealMedia files? shgr Avisynth Scripting 1 12-28-2004 04:55 AM
Avisynth: Automatic loading of AVS 2.0x plugins in AVS 2.5 vmesquita Avisynth Scripting 1 10-10-2003 01:16 PM
TMPGEnc: Problem loading .avs files Vitia Video Encoding and Conversion 13 03-03-2003 01:16 PM
Avisynth: Loading the AVS file into tmpgenc? deltaboy Avisynth Scripting 0 05-21-2002 07:50 PM
All times are GMT -5. The time now is 05:22 AM  —  vBulletin © Jelsoft Enterprises Ltd
