Quantcast TMPGEnc: Direct Show in TMPGEnc - digitalFAQ.com Forums [Archives]
05-31-2006, 05:25 AM
novagte novagte is offline
I am sure this question has probably been answered before on this forum but unable to find it so a quick question whenever I load an AVI file with subtitles and I set the direct show reader to the top under VFAPI plugins it loads vob subs at the bottom and then crashes TMPGENC. I am pretty sure that this seems to be a codec problem so I am currently running Klite codec pack on machine and wondered if this would be the problem. However single AVI files without subs work fine!
Site Staff / Ad Manager
05-31-2006, 05:47 AM
Dialhot Dialhot is offline
Actually I never use Directshow in tmpgenc, and if I would do, I will never use that to add subtitles ! You should use an avisynth script for that.
BTW, codec packs are often responsible of a lot of problems, and Klite is one of the packs I like the less. You should consider to remove it and install only the codecs you need.
Nevertheless, you can just try to upgrade the VSFilter (new name for Vobsub codec) to its last release. Go there :
http://sourceforge.net/project/showf...group_id=82303
DVD Burner: DVD+RW Direct On-disc Editing Hydeus Blank Media / Burning Discs 1 10-12-2004 03:30 AM
Direct capture to KVCD MPEG1? dominic01 Video Capturing / Recording 5 02-19-2004 05:38 AM
Recording Video: Direct DVD editing ? noize Video Capturing / Recording 4 02-11-2003 03:52 PM
Has anyone ever captured direct to KVCD? digitalvideo Video Capturing / Recording 1 06-20-2002 05:29 PM
TMPGEnc: Sequence header error from TMPGEnc encodings Gristle Video Encoding and Conversion 6 06-15-2002 03:07 AM
All times are GMT -5. The time now is 05:47 AM  —  vBulletin © Jelsoft Enterprises Ltd
