Quantcast Multiple DVD's on a Single DVD? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Authoring VCD, DVD, Blu-ray
06-14-2006, 06:47 AM
Icarus3000 Icarus3000 is offline
I was wondering if it was possible to burn multiple DVD's onto a single DVD without re-encoding.
To clarify: I have many children's DVDs that are quite short (~45 minutes each). Is there a way I can simply rip 3 or 4 DVDs to my HD, and then burn them onto a single DVD? Can this be done directly through Nero? What about DVD Lab? Or would I need to re-encode the whole thing?
Thanks!
Icarus
Site Staff / Ad Manager
06-14-2006, 07:05 AM
Dialhot Dialhot is offline
The short way is to use DVDShrink in "Reauthor" mode.
Drawback :
- quality of the image of course but as you don't want to reencode, you probably already supposed that.
- you loose the menu (no solution to keep the menu exists).
- you have to use the "title" select mode of you SAP to go directly to the next DVD. With some players, this is not convenient.
http://www.dvd-guides.com/content/view/46/59/
(other guides using other tools for the same thing : http://www.dvd-guides.com/content/category/3/78/59/)
06-21-2006, 01:11 AM
gamma gamma is offline
Drawback :
Actually, DVDremake pro can do all this, keeping the original menu's! Only it doesn't reencode or transcode anything. A option is to rip to HDD, then shrink each dvd until the total of all the dvd's is 4,35 GB, and then use dvdremake pro to burn them.
06-21-2006, 03:44 AM
I didn't know about DVDRemake. Don't you think the reverse situation is easier : First ripp, then remake, then shrink the final DVD ?
06-21-2006, 08:16 AM
lol, yes that's a lot easier
Authoring 4.9 GB on a single DVD-R? Dialhot Authoring VCD, DVD, Blu-ray 3 06-03-2005 05:51 AM
How can Large AVI can fit into a SINGLE DISK VCD? daniel_wu Video Encoding and Conversion 4 03-11-2004 11:54 AM
Multiple Disc SVCD to single KVCD gonzopdx Video Encoding and Conversion 25 03-08-2004 03:25 PM
fit a whole season of TV on single KDVD? davidmtml Video Encoding and Conversion 9 02-11-2004 05:28 AM
fit 92 Minutes on a single dvd? josejesus Video Encoding and Conversion 1 09-22-2002 10:55 AM
All times are GMT -5. The time now is 05:03 PM  —  vBulletin © Jelsoft Enterprises Ltd
