Quantcast Avisynth can't Execute (Error) - digitalFAQ.com Forums [Archives]
11-21-2006, 07:44 PM
epuleda epuleda is offline
My avisynth cannot execute after i restore my computer due to some problem.
when ever i want to run avisynth via avsedit this error will come out
"AVSEDIT ERROR:
An error occured while opening the avisynth script"
here are the sript i wrote:
AviSource("xxxxx.xxx",false)
Addborders(0,16,0,16)
LanczosResize(704,480)
BlindPP(cpu=4)
DCTFilter(1,1,1,1,1,1,0.5,0)
AssumeFPS(23.976)
before this, this script is running.
Site Staff / Ad Manager
11-22-2006, 06:17 AM
Dialhot Dialhot is offline
Is the problem only with avsedit or other apps ? Try to open the script with virtualdub for instance. I bet you miss an YV12 decoder, like Divx or Xvid codec. Install one of them.
Note :
1/ NEVER resize before using blindpp
2/ better not magnify the resolution (your source is smaller than 704x480, isn't it ? )
3/ should not add borders before to apply filters.
I don't know where you found this script but it'd better to look into the 'optimal script' or 'avi->kvcd' sections of the forum to find lot better ones.
11-22-2006, 10:14 PM
What i do is i just restore my pc few days earlier
and know what it works for me
But i still dont know what is the problem
Note :
Thank you fof the help and advice
Avisynth: ScriptClip Error Minister OI Avisynth Scripting 15 01-23-2005 12:16 PM
Un error con avisynth mcl_nemesis Convertir y Codificar Video (Español) 6 06-01-2004 01:20 AM
Avisynth: Blindpp error? vdk_au Avisynth Scripting 43 04-08-2004 09:26 AM
Avisynth: Error opening the avisynth file i76276 Avisynth Scripting 5 10-22-2003 05:56 AM
KVCD: KVCD_Predictor won't execute? Shaq Video Encoding and Conversion 3 11-19-2002 12:14 PM
All times are GMT -5. The time now is 02:36 PM  —  vBulletin © Jelsoft Enterprises Ltd
