Quantcast KDVD: All-in-one Program to Convert AVI Files? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Video Encoding and Conversion
12-11-2006, 05:48 PM
DragonZeal DragonZeal is offline
Is there a all-in-one program that can convert avi to kdvd?
Site Staff / Ad Manager
12-11-2006, 07:35 PM
Dialhot Dialhot is offline
Diko does "almost" kdvd (they called it BDVD) and is the only program of that kind. As we do not discuss about avi -> kvcd convertion anyway, you should go to Diko's forum to ask about it.
12-11-2006, 08:40 PM
rds_correia rds_correia is offline
Yes I was going to answer DIKO some hours before but it was AVI related and I don't know if DIKO still supports KDVD or at least loading custom matrices such as The Notch, now that they have BDVD.
__________________
Rui
12-12-2006, 09:23 AM
And what about all-in-one program for DVD to KDVD?
12-12-2006, 10:39 AM
"Oh then you seek Yoda..., take you to him I will..."
Ta-da-da-da!! I present you DVDREasy from my good friend Pedro .
If you convert from Anamorphic DVD to Non-Anamorphic KDVD you will surely have enough room for 2 movies with AC3 384Kbit, selective subs and a small motion-still menu.
Unfortunately last time I checked DVDREasy did single movie to KDVD though.
But I'm sure Pedro will look into that in the near future .
Cheers
__________________
Rui
Best program to cut VOB FILES ? NittoLive Video Encoding and Conversion 4 02-20-2007 08:49 PM
tool to convert the downloaded files to kvcd files? jenni Video Encoding and Conversion 2 01-21-2004 10:34 AM
prediction program for Kdvd to handle ac3 files? andybno1 Video Encoding and Conversion 4 01-14-2004 02:47 AM
KVCD: no program wants to play my .avs files? Edlund Video Encoding and Conversion 23 08-23-2003 01:49 AM
Is there a program that can demultiplex AVI files? willy_annand Video Encoding and Conversion 2 06-30-2003 04:16 PM
All times are GMT -5. The time now is 06:30 PM  —  vBulletin © Jelsoft Enterprises Ltd
