Quantcast KDVD: TMPGEnc Template/Parameters for 352x240 MPEG2 KDVD - digitalFAQ.com Forums [Archives]
12-31-2006, 10:12 AM
rab rab is offline
Is there a TMPGEnc template or certain perameters for a KDVD encoded at 352x240?
There only seems to be a template for Full D1 and Half D1, not 352x240 MPEG2.
Site Staff / Ad Manager
12-31-2006, 10:15 AM
Dialhot Dialhot is offline
Simply load any one of them and change manually the resolution to the one you want.
12-31-2006, 10:18 AM
rab rab is offline
Bloody hell that was quick!!
Ok, so everything else stays the same. Got it.
Cheers Phil.
12-31-2006, 02:12 PM
rds_correia rds_correia is offline
And a bit more in depth info from DVD Demystified:
http://www.dvddemystified.com/dvdfaq.html#3.4
And we're talking about DVD.
Please note that KDVD is basically a DVD using The Notch matrix.
Cheers
__________________
Rui
KDVD: TMPGEnc & KDVD Template bigbadmoshe Video Encoding and Conversion 24 12-26-2005 06:57 AM
KDVD: How to build a KDVD/KVCD cce-sp template ? sparskter Video Encoding and Conversion 5 07-07-2005 03:48 PM
TMPGEnc: No Video after adjusting KDVD Template bomybomy Video Encoding and Conversion 3 03-02-2005 04:19 AM
KDVD: can I just load the template in TMPGenc and hit start? Sparker Video Encoding and Conversion 2 06-10-2003 05:30 PM
TMPGEnc: Another audio sync problem using kdvd template blayzslayr Video Encoding and Conversion 6 07-05-2002 09:59 PM
All times are GMT -5. The time now is 06:14 AM  —  vBulletin © Jelsoft Enterprises Ltd
