Quantcast Hcmatic: Shutdown After Encode - digitalFAQ.com Forums [Archives]
01-17-2007, 02:02 PM
rainer rainer is offline
until phil adds this option to hcmatic, you can use this external application:
http://www.aumha.org/downloads/shutdown.zip
just add one of these lines to your .bat file
usage:
shutdown -u -t 0 for shutdown
shutdown -r -t 0 for restart
shutdown -h -t 0 for hibernate
haven't actually tried this myself but lets hope it'll work
edit: ok, just found out there's also a bit easier way. just add *SHUTDOWN to the last .ini file listed in .bat file.
Site Staff / Ad Manager
01-17-2007, 03:49 PM
Dialhot Dialhot is offline
How did you know that this is one of the things on my TODO list ? .
Note: shutdown is standard with winXP, but thank you for your link, I was missing it for my win2000k laptop.
01-17-2007, 03:53 PM
I read somewhere that especially in XP there is some problems with internal shutdown command.. it only shuts down windows but not the computer.
01-17-2007, 03:59 PM
Actually I have this problem on win2000 when I use the "*SHUTDOWN" parameter of HCenc. Windows and M$ is full of suprise
01-18-2007, 02:42 AM
kwag kwag is offline
Phil,
Check the sources on CQMatic and/or CalcuMatic, because I believe I already had the code in there for the shutdown process. It's just commented out
And BTW, congrats on your new tool
-kwag
Bitrates: Auto-shutdown after CQMatic finishes encode? dongxu Video Encoding and Conversion 2 09-12-2004 04:50 PM
Bitrates: Who supports an Auto-shutdown version of CQMatic? dongxu Video Encoding and Conversion 1 09-06-2004 11:36 AM
TMPGEnc: Auto shutdown option? Takkies Video Encoding and Conversion 5 04-28-2004 02:58 PM
DVD2SVCD: Please uncheck Auto Shutdown rpiepoli Video Encoding and Conversion 1 10-28-2003 02:36 PM
TMPGEnc: Automatic shutdown... is it possible? labomba Video Encoding and Conversion 7 02-05-2003 11:42 PM
All times are GMT -5. The time now is 01:49 AM  —  vBulletin © Jelsoft Enterprises Ltd
