Quantcast Encoding Causes Glitches on Every Scene - digitalFAQ.com Forums [Archives]
01-24-2007, 04:40 PM
audioslave audioslave is offline
I bought Disney's "Cars" for my eldest son a coulple of days ago. The problem is that he likes to turn on the DVD by himself (even though he's not allowed to! ) and I'm afraid he will destroy the DVD. My thought was to make a backup of the movie that he could play that instead of the original disc. I ripped the DVD with DVDFab Decrypter with "Movie Only" and the second angle (Swedish angle) only. But when I try to encode the movie I get glitches on every scene which used to contain more than one angle (ILVU's?). How can I correct this? I've tried all encoding programs out there: DVD Shrink, DVD-RB you name it. I'm sure there must be a way to do what I want...
__________________
AudioSlave
Site Staff / Ad Manager
01-24-2007, 04:59 PM
Dialhot Dialhot is offline
Tried to rip it with Ripit4me ?
DVDFabDecrypt probably badly managed the angles.
01-24-2007, 05:07 PM
Can I select what angle to rip with RipIt4Me? Or do I have to fix that after the rip?
EDIT
These warnings show up when RI4M start DVD Decrypter:
W 23:08:40 Protected Sectors List Imported Successfully!
W 23:08:40 159 areas have been marked as 'suspect'.
W 23:08:40 Dummy sectors will be inserted where necessary.
Something to worry about?
__________________
AudioSlave
01-24-2007, 05:52 PM
The rip seems to be going fine. So far so good.
__________________
AudioSlave
01-24-2007, 06:07 PM
not at all, this is the wonderfull behind Ripit4me
These sectors are the Arcoss protection. The tool is simply... removing it
01-24-2007, 06:23 PM
Great!
__________________
AudioSlave
01-25-2007, 12:03 PM
Excellent. It worked like a charm. Thanks a lot, Dialhot!
What do you recommend to encode the movie? I'm guessing DVD-RB is better than DVD Shrink, right?
If DVD-RB is recommended what encoder should I use? HC Encoder or CCE?
A lot of questions, I know...
__________________
AudioSlave
01-25-2007, 06:36 PM
Personnaly I :
- use shrink when compression is not under 80%. Depending on the source I keep the menu and in rare situation, some bonus. But I often take only the movie, with or without the end credits. The matter is : not under 80 %
- if I can't I use DVD-RB with CCE. As I have the pro version, I can choose to keep the menu or the bonus, but the free version does only full disc. As I really don't care about the bonus, I set the "half space and half size for bonus"
- Sometimes I even use shrink to extract the movie only but in "no compression" mode, and I use DVD-RB to compress the final result .
Note: you can use HCenc, it is as good as CCE.
Note2 : I use 1-pass OPV grant to RB-OPT.
What a scene! Prodater64 Off-topic Lounge 0 06-27-2004 06:31 AM
blur between scene changes is really noticeable? bigggt Video Encoding and Conversion 5 02-08-2004 06:09 PM
Detect scene change big Conversion et d'Encodage de Vidéo (Français) 1 12-27-2003 12:48 PM
Getting glitches on all encoded mpeg with any encoder? Orak Video Encoding and Conversion 6 05-19-2003 06:23 PM
KVCD: Scene Changes artifacts? Pike Video Encoding and Conversion 7 07-24-2002 10:40 AM
All times are GMT -5. The time now is 10:39 AM  —  vBulletin © Jelsoft Enterprises Ltd
