Quantcast Best Program to Cut VOB Files ? - digitalFAQ.com Forums [Archives]
01-28-2007, 01:04 PM
NittoLive NittoLive is offline
I would like to know the best program that i can just place my dvd, and view clips of the vob files, and cut scenes , and join vob files together, and output as vob?
Site Staff / Ad Manager
01-28-2007, 05:50 PM
Dialhot Dialhot is offline
Definitely Cutermaran.
It does note output as vob but elementary streams. No problem as no authoring programm actually works with vobs without demuxing them first into ES.
01-29-2007, 01:43 AM
kwag kwag is offline
Perhaps "Kutter"?
-kwag
02-20-2007, 01:12 PM
rds_correia rds_correia is offline
Originally Posted by kwag
Perhaps "Kutter"?
Hya Karl .
I was going to post the same but with a small remark: if the source file is bigger than 2GB then Kutter doesn't work properly.
An we know that this is not Kutters' fault but instead it's Purebasics' bug .
Cheers
__________________
Rui
02-20-2007, 08:49 PM
Yes indeed, Rui
-kwag
KDVD: All-In-One program to convert AVI files? DragonZeal Video Encoding and Conversion 4 12-12-2006 10:39 AM
prediction program for Kdvd to handle ac3 files? andybno1 Video Encoding and Conversion 4 01-14-2004 02:47 AM
KVCD: no program wants to play my .avs files? Edlund Video Encoding and Conversion 23 08-23-2003 01:49 AM
Is there a program that can demultiplex AVI files? willy_annand Video Encoding and Conversion 2 06-30-2003 04:16 PM
Any program that crops real media files?? andybno1 Video Encoding and Conversion 3 08-25-2002 01:31 PM
All times are GMT -5. The time now is 09:30 PM  —  vBulletin © Jelsoft Enterprises Ltd
