Quantcast KVCD: Besweet Gives Stupid Error Code - digitalFAQ.com Forums [Archives]
02-06-2007, 09:01 PM
mrsc mrsc is offline
First of all Thanks for the guide
ok here is my problem I have used the kvcd guide and everything has went fine so far, but where is it during BeSweet that i find the area to edit the ?B? parameter?
e. I usually use 128KB/s so click on the Copy Command to Clipboard, then open the command prompt, paste the command and edit the ?B? parameter to 128 and press enter.
f. You should get a MP2 file with the sound of the movie.
I thought i got it but man now im getting this stupid error code. I know you have covered this with several people before and i have searched every where on here for the answer you gave them but I cannot find it. Also im wondering how i get pt 1 & 2 together for the cd. does it happen during the multiplex or do I need to do something else? Can you help me to understand just these 2 things. Then I think I might have it
Thanks so much
__________________
Mrs.C
Site Staff / Ad Manager
02-07-2007, 03:32 AM
Dialhot Dialhot is offline
What guide ? Why editing the command line ? Where did you find this hint ?
The bitrate can be changed directly into the GUI and if you don't find any "b" parameter in the command line this is probably because it does not appear when the default bitrate is used (I think the default is 128 anyway).
02-07-2007, 08:40 AM
LOL if I tell you then I will have to kill you. Anyway I thought the same thing but I have tried to multiplex the video and audio several times and bang big error message when I put in the audio. Any ideas? I know I'm doing something wrong but I'm just not sure what.
Thanks so much
__________________
Mrs.C
02-07-2007, 09:27 AM
The main error is to imagine that I have a crystal ball that let me see into your mind
Either you give me all the details about where you find that, what you are doing and more other what is the EXACT errors you receive (or am I supposed to guess those also ?) or we can consider this thread as ended.
Up to you.
02-07-2007, 09:43 AM
Sorry. you mean you cant read minds Phil I thought all the French could do that. LOL
Ok first of all, the besweet version I have is 0.6. I hit the copy command to clipboard everything seems to be in 128Kbs but I'm not sure if it is or not because I dont know where to look to check. technology ---- so difficult. When I go to multiplex I get an illegal MPEG audiostream message. I have followed the guide to the letter but when I get to besweet I get confussed because of the whole 128KBs thing. Is this enough info to help me? Also the guide is the guide that is posted on here. The Convert AVI to KVCD guide that is.
__________________
Mrs.C
02-07-2007, 11:46 AM
THE LINK TO THAT GUIDE PLEASE !
There are 4 of them in the avi->kvcd section.
02-07-2007, 04:17 PM
http://www.kvcd.net/forum/viewtopic.php?t=5486
__________________
Mrs.C
02-07-2007, 05:22 PM
I think after spending some more time looking at the forums that I have it. I think. I changed the toolame to MPENC in BeSweet and everything seems to be going ok.
Now for my 2nd question. How do I combine 2 part avi's to make 1 kvcd? I hope this is the right forum to ask that.
Thank you so much for your help I really appreciate it.
__________________
Mrs.C
02-08-2007, 09:36 AM
Great then. Anyway this guide has a big problem : changing the bitrate is done directly into BesweetGUI as I said twice above. If you need to change it in the future...
Actually you should have read the disclamer before you registered, did you ?
We do not discuss about divx here so let close this discussion.
Nevertheless, to join 2 avi, use virtualdub (or virtualdub mod). You can find lot of guide for that on vcdhelp.com. For instance this one :
http://www.videohelp.com/guides.php?guideid=374#374
02-08-2007, 04:16 PM
Yes I read it, but I wasnt even thinking when I asked. Sorry. Thanks for the help Phil. It is greatly appreciated.
__________________
Mrs.C
BeSweet: Error 84, error configuring bsn! khusru Audio Conversion 14 02-25-2006 10:04 AM
KDVD: Pulldown Error code 19 emunity Video Encoding and Conversion 1 06-03-2005 03:37 AM
VirtualDub (Error code 100) X2003 Conversão e Codificação de Vídeo (Português) 2 10-01-2004 10:35 AM
BeSweet: Error 46 in BeSweet raquien Audio Conversion 9 07-10-2004 06:52 AM
HeadAC3he: error code 5 audioslave Audio Conversion 1 06-29-2003 03:00 AM
All times are GMT -5. The time now is 09:23 PM  —  vBulletin © Jelsoft Enterprises Ltd
