Quantcast KDVD: Need Guide to Make KDVD - digitalFAQ.com Forums [Archives]
04-08-2007, 07:44 AM
UNICHEM UNICHEM is offline
hi....please show step by step to make KDVD here..thanks..
Site Staff / Ad Manager
04-08-2007, 11:15 AM
Dialhot Dialhot is offline
Doing a DVD is like doing a VCD except that you use a different template and need an authoring tool in the end. So basically all what you need is a guide for an authoring tool. As there are a lot of them (guide and tools) on the net, that's probably why there is no specific one there.
At which step are you stuck ?
04-08-2007, 08:37 PM
thank for ur feedback,the problem now is how to authoring kdvd at the end.
04-08-2007, 11:29 PM
Do you have a tool ? Else I suggest Tmpgenc DVD Author for its smplicity or DVD Lab Pro for its convenience and skills. That's the one I use.
06-09-2007, 07:17 AM
leech leech is offline
what do i need to do in tmpgenc
06-09-2007, 11:31 AM
kwag kwag is offline
See answer to your other post.
-kwag
06-09-2007, 07:26 PM
Redge Redge is offline
Send a message via ICQ to Redge Send a message via MSN to Redge
I'm pretty much completely new to TMPGEnc, and KDVDs/KVCDs and everything, really appreciate this site, probably the best $3 i've ever spent.
Just another question about KDVD's though, and I thought this was the most appropriate thread.
What i've been doing so far to make KDVD's, is using the v4 script posted elsewhere in the forums, and using the template for TMPGEnc from
http://www.kvcd.net/dvd-models.html to encode the video.
My question is, using these tools, I'm under the impression that I'm encoding with a constant bitrate for the video stream, but I'm just wondering if that's true or not, and is there a way to get to a VBR for better quality?
Let me know if i'm being a bit scarce with details.
KDVD: XViD TV Episodes to KDVD Guide Dassin Video Encoding and Conversion 24 06-28-2006 11:29 AM
How to make a kdvd? Muse Video Encoding and Conversion 6 08-18-2004 06:35 AM
How to make a kDVD? LeeKuid Video Encoding and Conversion 5 06-22-2004 08:02 PM
Bad framerate? What I have to do for to make a kdvd? zagor Video Encoding and Conversion 7 05-26-2004 08:12 AM
Is there a guide on how to make a kdvd? Anonymous Video Encoding and Conversion 4 02-05-2003 10:20 PM
All times are GMT -5. The time now is 04:32 AM  —  vBulletin © Jelsoft Enterprises Ltd
