Quantcast KDVD: Lord of the Rings Trilogy on one DVD - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Video Encoding and Conversion
04-17-2007, 10:18 AM
rainer rainer is offline
don't judge me just yet!
This wasn't ment to an example of kdvd capabilities. I just wanted to have all movies on one disc for convenience.
Total runtime: about 8 hours 40 minutes
Audio: 160kbit Stereo (no chance keeping the original 5.1 track)
Vid bitrate: HCenc @ Q6,36
Resolution: 352x576
Script: MA+shit
Total size: 4,3gb (original over 20 gigs)
Results ain't dvd quality (surprise!) but looks good enough on my shitty 28" tv.
Site Staff / Ad Manager
04-18-2007, 12:25 AM
supermule supermule is offline
can you post any screenshots for our reference ???
04-18-2007, 02:25 AM
04-18-2007, 11:18 AM
Dialhot Dialhot is offline
You're right. That's not so bad at all !
04-19-2007, 05:00 AM
looks decent enough, HCenc has really improved in the latest version (0.20) on the quality factor and for low BR.
04-19-2007, 07:54 AM
Version 0.19 was used with those though....
04-20-2007, 04:22 AM
Ops! I assumed
07-18-2007, 07:13 AM
Sagittaire Sagittaire is offline
Well it's 1000 Kbps video encoding with 320*416 real resolution -> imply 3100 Kbps for 720*576 real resolution with the same bits/pixel.
__________________
Le Sagittaire
Inutile de discuter avec moi ... j'ai toujours raison ... en tous cas j'en suis convaincu et c'est le principal ...
07-18-2007, 08:00 AM
Less than this because 720*576 is the frame resolution, not the image one (the LOTR are in widescreen). Or else you have to compare it with 352x576 and not 320x416.
Nevertheless I don't understand your point : are you saying that it's normal that the reslut is not so bad as 3100 is yet a decent bitrate to do encodes ?
07-18-2007, 11:47 AM
I speak about only real image here.
Yes 3100 Kbps is a good bitrate for 720*576 resolution: with medium compressibility source, quality will be always good if you use a good MPEG2 encoder.
If you want comparison:
- Professional MPEG2 encoding use 4-6 Mbps for 720*576
720*576 for real image: 0.38 - 0.57 bpf
720*416 for real image: 0.53 - 0.80 bpf
- This example use 1 Mbps for 352*576
320*416 for real image: 0.30 bpf
It's 20 GB -> 4 GB converstion for size but ratio for bpf is not 1:5 but only 1:2. In fact for bpf this encoding is simply like backup convertion at 50% and use certainely the same average quantizer ...
__________________
Le Sagittaire
lord of the rings 1 & 2 movies onto 1 DVD Per Movie! andybno1 Video Encoding and Conversion 43 12-15-2004 05:21 PM
Avisynth: Lord of the Rings SCRIPT for VCD ocelot Avisynth Scripting 0 01-20-2003 08:36 PM
kdvd: convert lord of the rings from two DVDs to one? m0rdant Video Encoding and Conversion 6 01-06-2003 04:01 AM
KVCD: Lord of the Rings and the LBR Template LadyMiles Video Encoding and Conversion 5 10-25-2002 03:50 AM
Avisynth: Need avs script for Lord of the Rings akrein62 Avisynth Scripting 0 08-21-2002 09:06 AM
All times are GMT -5. The time now is 04:37 AM  —  vBulletin © Jelsoft Enterprises Ltd
