Quantcast KVCD: can't Trim File? - digitalFAQ.com Forums [Archives]
05-04-2007, 07:38 AM
FFCcottage FFCcottage is offline
Hi can anyone help me, I've finished multiplexing a file and it came out just too big 843,515kb so I just wanted to cut a fraction of the end of the file so that it will fit on one CD.
First I tried in TMPGEnc Merge & Cut but it showed my file as only 17minutes long. I have two splitter software and both of them show the file as only 17 minutes long. I've tried the file in four players that I have and it is fine showing the correct time 1hr 35mins.
Has anyone any idea why this is happening.
Site Staff / Ad Manager
05-04-2007, 07:42 AM
Dialhot Dialhot is offline
What did you used to multiplex the file ?
Nevertheless, you should be abble to cut it with cuttermaran, that is free.
http://www.videohelp.com/tools/Cuttermaran
05-04-2007, 07:52 AM
I used TMPGEnc to multiplex, I have two splitters already but as I said they are both showing my file as only 17 mins long, when it should be showing 1hr 35min.
The splitters will work it is just my file is not showing the correct time.
I will download the one you have suggested and see if that works. thanks
05-04-2007, 09:22 AM
I do'nt remember to have this also in tmgenc, but FYI it is very common to have some tools, and even standalone players that become completly nuts with the times displayed. This is because we are using VBR MPEG1, that is not the standard for VCD (standard is MPEG1 CBR).
How can you trim kvcd without screwing it up? phuquehair Video Encoding and Conversion 5 02-01-2005 10:03 AM
Avisynth: Trim and ConditionalFilter? Mental Avisynth Scripting 23 11-01-2004 06:19 PM
Avisynth: Trim? bigggt Avisynth Scripting 13 09-04-2004 03:05 AM
KVCD: Trim pixels from each side? nicksteel Video Encoding and Conversion 3 04-27-2004 01:06 PM
KVCD: how do I trim the audio? Jellygoose Audio Conversion 7 01-20-2003 03:34 PM
All times are GMT -5. The time now is 02:12 AM  —  vBulletin © Jelsoft Enterprises Ltd
