Quantcast Hcmatic: Scene Change Detection - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Avisynth Scripting
05-04-2007, 09:44 PM
supermule supermule is offline
Why is the HCmatic not using the scene change detection in its prediction routine and then the encodes ???
KVCD specifications suggests usage of scene change detection, if the encoder permits.
Site Staff / Ad Manager
05-05-2007, 03:40 AM
Dialhot Dialhot is offline
Because SCD completely screw the prediction and I always said that it's nut to use it. It was the case with CQMatic, and it's still the case.
Prediction is based on slices (in case of HCMatic : 1 second each minute of movie). At each slice end there is a very big chance that the SCD algorythm detects a scene change and insert an I frame. The result is that the % of I frames in the encoded sample is much more important than the reality in the whole movie. Thus the sample size is bigger that it should be, and in the end the Q value found is way under the ideal value.
05-05-2007, 06:24 AM
rds_correia rds_correia is offline
Exactly!
It doesn't matter if you're using HCMatic, CQMatic or even a manual prediction approach.
If you are running a prediction routine you have to disable the scene change detection otherwise you'll get mistaken output figures for Q.
As for enabling SCD for final encoding I just don't know...
Sometimes I do that and I get a bit oversized movies that I have to run through DVDShrink or then reencode but sometimes I do that and the outcome is pretty close to the final predicted sizes.
So IMHO there's no sense in using SCD at all.
Cheers
__________________
Rui
05-05-2007, 08:24 AM
Thanks for the info!!
05-11-2007, 12:07 AM
Boulder Boulder is offline
Cheers
It's strongly recommended that scene change detection is enabled. HC has a very good algorithm which will catch them very well. Otherwise you might end up in situations where a scene change is P-B which means that there will be severe degradation of the image quality before the next I-frame arrives.
05-11-2007, 02:27 AM
You are right. I never think about that. Not sure this is noticiable, at least, I never have been chocked by that ((with my eyes, while watching at the video I mean), but I will think about activating it.
05-11-2007, 03:09 AM
In prediction, it is better to disable it as you already had figured. But in the regular encode, there's really no good reason not to use it..I recently did a test in which I noticed what happens when scd is not used or doesn't work. There was a fast action scene followed by a lo-motion scene, the scene change was P-B as CCE didn't for some reason put an I-frame there. The first few frames of the latter scene looked really terrible as they were predicted from incorrect motion vectors due to the missing I-frame. It was quite noticable during playback, in fact it was why I started looking at the scene more thoroughly.
05-11-2007, 11:32 PM
Thanks for your comments Boulder .
Cheers
__________________
Rui
05-19-2007, 08:21 AM
I'm currently regarding a video that I did not encode where SCD is obviously off, and the result is awfull. Each SC the frame is at best pixellated, at worst awfullyblended.
I will add the SCD to final encode in HCMatic once I verify that does not screw up the final filesize too much.
Avisynth: Dynamic Linear Adaptive Filtering and Scene Change Detection supermule Avisynth Scripting 3 09-15-2006 01:45 AM
Avisynth: Scene Change Detection? Prodater64 Avisynth Scripting 1 02-29-2004 09:05 PM
Detect scene change big Conversion et d'Encodage de Vidéo (Français) 1 12-27-2003 12:48 PM
KVCD: Scene change detection? Boulder Video Encoding and Conversion 1 01-27-2003 11:50 AM
KVCD: Detect Scene Change? Pike Video Encoding and Conversion 1 08-08-2002 12:56 PM
All times are GMT -5. The time now is 05:04 AM  —  vBulletin © Jelsoft Enterprises Ltd
