Quantcast Avisynth: No Function Called BlindPP ? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Avisynth Scripting
05-26-2007, 05:28 AM
WOWIEGURL WOWIEGURL is offline
Send a message via ICQ to WOWIEGURL
I have both grip.dll and gripfit_YV12.dll but it keeps telling me that. can someone help?
THanks
WOWIE
Site Staff / Ad Manager
05-26-2007, 05:39 AM
Dialhot Dialhot is offline
BlindPP is included in mepg2dec3 or dgdecode. you need one of them too.
(if you would have taken all my plugin directory that I already sent to you, you won't have this kind of problem).
Note: and please, stop posting in that forum section when your problem has nothing to do with an "optimal" script. There is an avisynh section for that.
05-26-2007, 05:41 AM
problem is after I put all the .dlls from your rar folder my computer tells me there isn't enough working memory to use and I have to remove some. So its not like I'm not trying to read your instructions. But thanks for telling me I'm posting in the wrong section
05-26-2007, 10:29 AM
Not enought memory ? The whole directory is only 6 MB, I barely firugre that you don't have enought memory to load it all.
You should have something else in that directory that does not suit avisynth. Try to rename your old directory and simply put mine.
04-02-2014, 08:11 AM
nanban001 nanban001 is offline
Sorry Dialhot this is old thread but i missed your PlugIns will you be able to share again i need them as i am having same error i cannot load BlindPP in
Avisynth: BlindPP(cpu=4) Vs Deblock() supermule Avisynth Scripting 0 07-21-2006 03:50 AM
Avisynth: PARanoia and ADS function comparison rds_correia Avisynth Scripting 10 10-09-2005 04:30 PM
Avisynth: Is is possible to use the trim() function with audio supermule Avisynth Scripting 3 09-10-2005 03:05 AM
Avisynth: Ads() a function using a masked denoising etc incredible Avisynth Scripting 97 10-19-2004 06:52 AM
there is no function called blindPP? bigggt Video Encoding and Conversion 3 08-22-2004 12:22 PM
All times are GMT -5. The time now is 10:05 AM  —  vBulletin © Jelsoft Enterprises Ltd
