11-01-2007, 08:37 AM
Hi all,
What matrix are u using when you have room enough on your dvd, lets say an average bitrate of 3500?
I have the impression that under the same conditions (bitrate, quant characteristics etc) the notch matrix is a little bit less crisp and sharp when compared with the standard cce matrix?
Is this true, or are my eys playing tricks on me
Site Staff / Ad Manager
11-01-2007, 09:16 AM
The notch matrix is aimed to low bitrate and it's not surprising that you find better ones for upper bitrate. Actually I never thought about doing some test
11-01-2007, 09:28 AM
Which matrix do you use for encodings at upper bitrate?
11-01-2007, 11:39 AM
As I said, I never did any tests. I used to put 2 or 3 movies on a DVD, so using the Notch, and when I started to use DVD-RB with CCE to do a 1-1 backup, I never changed my settings .
11-07-2007, 04:12 AM
Ok, then you're using the standard CCE matrix.
BTW, after some more testing I really can't tell the difference between encodes with the CCE matrix and notch matrix. All tested at higher bitrates. Of course, the notch compresses more than the CCE matrix so a higher quality can be archieved.
11-07-2007, 04:22 AM
No, I use kvcd-Notch - actually I directly patched it into CCE using an hex editor just to be sure no other matrix will be used ).
11-07-2007, 02:38 PM
But are you sure the that rebuilder doesn't override this, as it sets all settings including the selected matrix into the config file as far as I know.
11-07-2007, 06:10 PM
DVD-RB Free didn't last time I used it (I think that is why I patched CCE), but since a year I'm using DVD-RB PRO that allows to select the matrix you want, and of course I select the Knotch.
All times are GMT -5. The time now is 05:13 PM — vBulletin © Jelsoft Enterprises Ltd
