Quantcast Two Small Movies onto one VCD? - digitalFAQ.com Forums [Archives]
03-03-2008, 10:31 AM
tambrown tambrown is offline
Is it possible to burn 2 movies onto 1 cd with nero. The files are small enough to fit but nero only picks up 1 cue and wants to go. Anyone help?
Site Staff / Ad Manager
03-03-2008, 11:28 AM
Dialhot Dialhot is offline
It is not possible to merge 2 cue/bin files but you can mount them in a virtual drive on your disc (with Nero or using Daemon tool for instance), extract the movies, and create a brand new disc with them.
But the easier would be to go to the first step : what did you use for creating these cues ? Can't you do a 2-movie disc with it ?
03-03-2008, 01:55 PM
Thanks Dialhot. I have been trying to use nero 7 but to no availe
03-03-2008, 01:57 PM
Sorry I used cue maker 2 and vcdeasy
03-03-2008, 06:12 PM
Then it would be possible to do that with vcdeasy. The hardest part it to make something like a menu to select one movie or the other.
Go on Doom9 ou vcdhelp.com, they have great tutorials for any kind of tools.
Small HCenc m2v output nicksteel Video Encoding and Conversion 6 01-18-2007 09:09 AM
HCenc: Little bug and small request concerning HC Dialhot Video Encoding and Conversion 2 05-13-2006 12:38 PM
Small pauses in video? andybno1 Video Encoding and Conversion 11 04-10-2004 01:34 PM
KVCD: Small display on tv kepsy Players, DVRs, Media Centers 9 12-18-2003 09:17 PM
cannot see the subtitles because my screen is too small? the5star Video Encoding and Conversion 0 05-16-2003 08:24 AM
All times are GMT -5. The time now is 08:38 AM  —  vBulletin © Jelsoft Enterprises Ltd
