Quantcast DVD2AVI: Field Order Transition Error - digitalFAQ.com Forums [Archives]
05-16-2008, 10:34 PM
Redge Redge is offline
Send a message via ICQ to Redge Send a message via MSN to Redge
Hey, just having a problem encoding a video; Ripped with DVD Decrypter, and now trying to save the project using DGI Index 1.5.
I keep getting the following error when saving the .d2v file:
A field order transition was detected.
It is not possible to automatically decide if this should be corrected.
Refer to the DGIndex User's manual for an explanation.
You can choose to correct it now by hitting the Yes button below or you can choose to correct it later using the Fix D2V tool.
I tried fixing it then, fixing it later, and not fixing it at all, and in all situations whenever i load it in TMPG Enc it only encodes the first two hours of the movie, cutting off the last 30 minutes.
I double checked when i saved the D2V file to make sure the whole movie was selected, and am a bit at a loss for what else to do.
Any ideas?
Film Info:
Film Type: Film 99%
Frame Type: Progressive
NTSC
Site Staff / Ad Manager
05-16-2008, 10:42 PM
Dialhot Dialhot is offline
Try to not open the d2v directly into tmpgenc but use an avisynth script (even if it is just composed of the command "dgdecode_mpeg2source(<your d2v here>").
05-16-2008, 10:45 PM
Sorry, i should have mentioned that I was doing that.
Using the latest optimal script and using the dgdecode to deal with the mpeg2source.
I know you got something else in your bag of tricks!
Appreciate the help
05-17-2008, 12:36 AM
Unfortunately I never had such error.
Can you open the script in virtualdubmod and see if you can drag the cursor after the 2 hours of movie ? Just tro verify if the problem comes from tmgenc or the d2v itself.
You can try to use HCEnc also, unless you are encoding in MPEG1.
05-17-2008, 04:54 PM
digitall.doc digitall.doc is offline
Sorry me, I'm not going to be very precise here.
I had this problem once. I remember I solved it following recommendation in DGIndex message: I think I used Fix D2V tool in DGIndex with success.
Did you try to fix it with Fix D2V?.
Recording Video: Wrong field order? Anerboda Video Capturing / Recording 6 01-27-2005 08:39 AM
Which setting in CCE is Field Order? rs008f Video Encoding and Conversion 8 02-26-2004 06:53 PM
TMPGEnc: Field order for interlaced source mistermickster Video Encoding and Conversion 6 12-12-2003 11:49 AM
Avisynth: Field Order? nicksteel Avisynth Scripting 6 10-28-2003 09:35 AM
VirtualDub: Correcting Field Order and Swapping in interlaced sources ozjeff99 Video Encoding and Conversion 9 05-16-2003 02:21 AM
All times are GMT -5. The time now is 10:19 AM  —  vBulletin © Jelsoft Enterprises Ltd
