Quantcast Avisynth: Help with Multi-Episode Source - digitalFAQ.com Forums [Archives]
07-25-2008, 10:28 PM
tengo6dedos tengo6dedos is offline
hello, i have tv-shows dvds that i want to backup but i want to cut the intro and the ending, how can i do this via avisynth pre-encoding and how can i match the audio?
thanks
Site Staff / Ad Manager
07-26-2008, 11:52 AM
digitall.doc digitall.doc is offline
I will tell you how I do this.
In avisynth there's a filter called Trim (you can read in Avisynth Documentation for better explanation), where you can select the frame 'from' you want to encode, and 'to' you want to encode:
Trim(From, To)
Related to audio, it depends on your source audio. If already in wav, I usually load it in Audacity (http://audacity.sourceforge.net/), under view change selection to Frames, and I select the audio based on the frames of video I already encoded. No syncing problems with this way.
If your source is not a wav, demux it, and you can load it in headac3he and convert to wav. After that, and depending on your destination, you will encode the trimmed audio to mp2 or ac3.
I believe that in avysinth there are also audio filters, but never used avisynth to trim the audio. Maybe anybody else...
07-26-2008, 06:32 PM
Dialhot Dialhot is offline
A lot faster if your sources are DVDs : simply use the "start - end" feature of DGIndex (the buttons '[' and ']' at the bottom) ! It will generate the d2v AND demux the audio corresponding to the part you have selected, providing you the delay you will have to enter into your mux tool (if you use directly the demuxed file) or into the convertor (if you encode then in mp2).
07-26-2008, 07:42 PM
thanks a lot, how come i never saw that dgindex function hehe
07-26-2008, 08:25 PM
6 fingers and only 1 eye may be
AviSynth Multi-Core? tengo6dedos Avisynth Scripting 13 10-27-2009 05:30 AM
a separate vob file for each episode? Evangelion-01 Video Encoding and Conversion 3 10-13-2004 11:25 PM
Avisynth: How to select source range with Avisynth? rs008f Avisynth Scripting 4 09-21-2003 11:31 PM
Episode II kwag Off-topic Lounge 5 03-19-2003 07:33 PM
KVCD: only want 1 episode on a disc for quality? m0rdant Video Encoding and Conversion 0 12-20-2002 03:09 AM
All times are GMT -5. The time now is 03:44 AM  —  vBulletin © Jelsoft Enterprises Ltd
