Quantcast Scheduled Recording on WinTV-Go Card? - digitalFAQ.com Forums [Archives]
01-20-2003, 11:28 PM
ozjeff99 ozjeff99 is offline
Hi to all. I have been using my Hauppauge WinTV-Go for some time with great results on captures. I want to be able to schedule TV recordings in advance but have not been successful in finding any non-commercial software that will change channels etc. for this particular card. Hauppauge have software for the PVR card and VirtualdubVcr does not have an XP compatible version yet as I understand. Commercial software should do it(eg. WinDVR or PowerVCR) though.
Anyone got any suggestions (Kwag I know you have this card).
Cheers.....Jeff
Site Staff / Ad Manager
01-20-2003, 11:48 PM
kwag kwag is offline
Hi ozjeff99,
WinDVR is very good. It's about the best real-time software encoder I've seen. Better that PowerVCR. I like the quality much better. You can capture MPEG-2 at a very high bit rate, and then transcode to MPEG-1 with a KVCD template. The results are pretty good
I'm not using this capture card anymore, because I now capture with the Panasonic DMR-E20 to DVD-RAM. Then I take the DVD-RAM to my PC and transcode. Nothing can beat that as a real-time hardware encoder. I haven't seen any hardware cards that approach the quality that Panasonic has achieved with that machine.
-kwag
01-21-2003, 01:45 AM
Thanks Kwag. Yes I have been tossing up whether to go the expense with that Panasonic unit or the newer one (the ethernet connection seems interesting) . Without going in to details, in order to have access to all cable channels and switch them by the either a new unit or in software I need to invert the cable video on the way in or on the way out. Dscaler does this nicely. So I'll try for a software solution first and see where that takes me.
Cheers....Jeff
01-30-2003, 10:54 AM
MrTibs MrTibs is offline
There is a mod of Virtualdub that has tuner control and scheduled recording. I've downloaded it but I haven't tried it.
Let me know if you can't find it, I'll dig around.
02-06-2003, 09:47 AM
digitalize digitalize is offline
The site is www.virtualdvr.org. I have not tried the software though.
03-07-2003, 01:04 PM
deleted
Recording: Best capture card for under $100 ? zerotype Video Capturing / Recording 5 07-28-2004 08:52 AM
WinDVR (WinTV card) into DVD2AVI into TMPGEnc for KVCD? nicksteel Video Capturing / Recording 3 07-17-2003 11:01 PM
Recording Video: Which card should I buy? nicksteel Video Capturing / Recording 21 03-07-2003 07:37 PM
Recording Video: Having a little problem with wintv andybno1 Video Capturing / Recording 0 01-21-2003 02:06 PM
Recording Video: VirtualDub from WinTV Go Scav Video Capturing / Recording 12 09-27-2002 05:30 PM
All times are GMT -5. The time now is 08:26 PM  —  vBulletin © Jelsoft Enterprises Ltd
