Quantcast Recording Video: Green in Capturing - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Video Capturing / Recording
04-01-2003, 03:17 PM
andybno1 andybno1 is offline
Send a message via MSN to andybno1 Send a message via Yahoo to andybno1
before I even capture from VCR when there is red green appears in the red, anyone know why?
Site Staff / Ad Manager
04-02-2003, 09:20 AM
el_mero_zooter el_mero_zooter is offline
Send a message via MSN to el_mero_zooter
Red Green,
what's he doing in your captures..?
http://www.redgreen.com/
zTr
04-03-2003, 03:49 PM
but seriously, why am I gettin green in parts of the red in the preview box and finished avi capture file.
04-03-2003, 04:26 PM
which codecs do you have installed by chance?
04-03-2003, 04:30 PM
I use morgan mjpeg codec but it doesn't look like its down to the codec, the fact that it shows in the preview window before I have even captured.
04-03-2003, 05:14 PM
do you have any divx codex installed like the nimo codec pack etc...
any windows media player 9 or its codec?
What OS are you using? Do you off-hand if you're using vfw or wdm for capture (as a video driver)?. What direct X version? Which capture board/video card?
Have you by chance tried another vcr, another tape?
If you capture from a camcorder or tv or from dvd, does it behave the same way?
Do you have any type of adobe gammas and the correct drivers for the monitor installed?
ztr
04-04-2003, 03:46 PM
I have winxp, vfw no nimo codecs I have divx mpeg-4 low and high motion codecs, latest direct x, hauppauge pci card.
no I have not tried capturing form another tape or vcr casue its a lot of messin about to get another to my room.
04-05-2003, 07:44 AM
I hear ya on dat one.... same here....
is it feasible to take a screenshot of the red green?
04-05-2003, 03:17 PM
of cause its feasible I just need a little time to do the screenshot.
04-06-2003, 12:06 PM
sorry it took time, I just forgot to take the screengrab but here it is. I also noticed it in wintv program as well when I tuned my card in via the program.
EDIT: ooooppss double post.
Recording Video: A little Guide for better capturing incredible Video Capturing / Recording 11 08-23-2006 08:23 PM
Recording Video: Best capturing software? bigggt Video Capturing / Recording 0 03-17-2006 07:35 PM
Recording Video: DScaler and capturing andybno1 Video Capturing / Recording 4 04-28-2003 11:09 AM
Recording Video: Advice on capturing conquest10 Video Capturing / Recording 4 04-13-2003 06:26 PM
which vcr to buy for recording/capturing video? rendalunit Video Capturing / Recording 3 09-10-2002 02:51 PM
All times are GMT -5. The time now is 03:05 PM  —  vBulletin © Jelsoft Enterprises Ltd
