Quantcast VOB ID in Subtitle - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Subtitles
04-22-2003, 09:22 AM
syk2c11 syk2c11 is offline
Hi there,
If the DVD is a dual layer one (DVD-9), there is a layer break, and whenever there is a layer break, the subtitle's Vob ID is changed from 1 to 2 (be sure not to mix up with Vob Cell). When I authored my final output (of course it is KDVD ), IFO Edit did not recognize when it reached the subtitle's layer break (i.e. subtitle's Vob ID changing from 1 to 2), therefore, the 2nd half of the movie had NO subtitle at all. How can I change the subtitle's Vob ID (use "1" for the whole set of subtitle) so that IFO Edit will recognize it? By the way, I used VOB Edit to rip my subtitle stream. Thanks in advance!
I used subresync.exe (a file inside VobSub.zip) to check, it showed subtitle's Vob ID.
Site Staff / Ad Manager
Adding subtitle to .mpg cyron Subtitles 15 09-21-2004 05:00 AM
Subtitle workshop julio Conversão e Codificação de Vídeo (Português) 3 08-03-2004 05:10 AM
Guide: How to rip subtitle from avi wgamer Subtitles 13 03-02-2004 04:25 AM
Subtitle guides, anyone? Kane Subtitles 11 09-21-2003 05:12 PM
Permanent subtitle? Add subtitle into video? TBO Subtitles 4 08-02-2003 06:19 PM
All times are GMT -5. The time now is 07:15 AM  —  vBulletin © Jelsoft Enterprises Ltd
