Quantcast KVCD Looked a Lot Worse than Video on Computer? - digitalFAQ.com Forums [Archives]
07-01-2003, 12:02 AM
kinggee kinggee is offline
Send a message via MSN to kinggee
i don't know if this is a problem or not, but i just played a sample i recently encoded with Tok on my tv and it looked a lot worse than it did when i played it on my computer.
isn't it supposed to be the other way around
Site Staff / Ad Manager
07-01-2003, 12:08 AM
kwag kwag is offline
That's right
What resolution did you encode, and what was your CQ
-kwag
07-01-2003, 12:14 AM
hey kwag,
my resolution was 528x480 - PAL, but my tv can play ntsc resolutions
my cq was about 51.2, movie length was just under 2 hours
07-01-2003, 12:16 AM
If your player and TV can play NTSC, did you also encode at 23.976fps instead of 25fps
07-01-2003, 12:18 AM
no, i just encoded at 25 fps
could this be the problem
07-01-2003, 12:21 AM
Well, if you encode at 23.976fps, you're going to get a higher CQ, and better quality
Try a small clip first to see if 23.976fps plays smoothly
-kwag
07-01-2003, 12:22 AM
ok, will do
thanks mate
07-01-2003, 02:13 AM
yes! my tv plays 23.976 smoothly, and now i get a higher cq and better quality
i never guessed that a small change like that could do so much
thanks kwag
AUDIO AND VIDEO problems WATCHING ON TV, but not computer? WOWIEGURL Players, DVRs, Media Centers 8 06-05-2004 09:45 PM
Is AverTV much worse than PVR-250 ? bman Video Capturing / Recording 5 11-20-2003 03:06 AM
KVCD: no success? quality worse than original? D Rated Video Encoding and Conversion 0 07-08-2003 08:58 AM
kvcd: Why is there a smaller resolution with a bigger filesize and worse quality? a_star62 Video Encoding and Conversion 0 11-22-2002 01:22 AM
KVCD: AVS script much worse than the straight movie Bigswaffo Video Encoding and Conversion 47 06-26-2002 10:24 AM
All times are GMT -5. The time now is 07:58 AM  —  vBulletin © Jelsoft Enterprises Ltd
