Quantcast An Easy Way of Resizing and Positioning Subtitles? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Subtitles
07-01-2003, 02:02 AM
audioslave audioslave is offline
I'm having trouble finding the right size and position when I'm creating subs with VobSub. Is there a way of auto resizing and positioning the subs? To make te subs look like they do on the DVD? This is driving me nuts!
I'm open for suggestions of other programs and methods as long as it solves my problem.
__________________
AudioSlave
Site Staff / Ad Manager
07-01-2003, 01:07 PM
Oh, come on. Anybody, pleeeeease.....
__________________
AudioSlave
07-02-2003, 07:19 AM
GFR GFR is offline
You can position the subs with Vobsubconfigure. Make sure you press OK in Vobsubconfigure, then reopen your avs to load the changes.
I'd like to know how to resize, too.
A hard way would be creating a separate clip in your avs to hold only the subs over a black background, tweak it to your liking and then overlay it on the actual movie. The overlay thing is a bit complicated, check Avisynth docs please. I didn't have much luck with this method
07-02-2003, 08:26 AM
Thanks mate!
I think I found a solution to my problem. I'm at work right now but I'll post my solution as soon as I get home.
__________________
AudioSlave
05-21-2004, 08:14 AM
WOWIEGURL WOWIEGURL is offline
Send a message via ICQ to WOWIEGURL
Have been able to find time to post your method of repositioning the subs?
Subtitles: Adding .srt subtitles to a KVCD movie xpronic Subtitles 13 06-12-2004 09:33 PM
Easy CD-DA Extractor 6.5 vdk_au Audio Conversion 7 02-15-2004 10:34 AM
CDR-DAO problems in VCD Easy? GMan Authoring VCD, DVD, Blu-ray 10 03-09-2003 01:53 PM
VCD Easy v1.1.4b5 released jorel Authoring VCD, DVD, Blu-ray 0 01-05-2003 09:57 PM
KVCD Screen Positioning wrong? Starfury1 Players, DVRs, Media Centers 4 11-21-2002 09:45 PM
All times are GMT -5. The time now is 03:12 PM  —  vBulletin © Jelsoft Enterprises Ltd
