Quantcast Direct Capture to KVCD MPEG1? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Video Capturing / Recording
07-08-2003, 09:20 AM
dominic01 dominic01 is offline
Hello KVCD Gurus,
First is it possible to directly capture to KVCD format? Today I tried something like changing resolution and bitrate but my DVD player doesnt play. Has anyone tried this?
I am using Leadtek tv2000XP deluxe card and I can capture directly to MPEG1 and MPEG2.
Could you please tell me what parameters I should change to capture directly to KVCD format.
Regards
Dominic
Site Staff / Ad Manager
07-08-2003, 11:04 AM
kwag kwag is offline
Hi Dominic,
Only if your card lets you change these parameters: http://www.kvcd.net/e107/article.php?21.255
-kwag
07-08-2003, 01:25 PM
Originally Posted by kwag
Hi Dominic,
-kwag
I have the above options available for changing parameters. Could you please help me what I can change. Sorry I dont have any idea what these are.
I took these options from Ulead Video Studio SE DVD.
Regards and Thank You
Dominic
07-08-2003, 01:55 PM
Sorry Dominic,
But I don't think that card supports custom matrixes
And changing the GOP only is really not going to help.
-kwag
02-19-2004, 05:01 AM
password password is offline
the link does not work but does ati all in wonder 8500dv or using windvr3 work ? thanx in advance
02-19-2004, 05:38 AM
incredible incredible is offline
Send a message via ICQ to incredible
As I know Leadtek do ship their cards with an software mpeg encoder!
That means already a worse quality cause of bad and therefore fast motion estimation algorythms are used. Every more compression setting you add, the even more worse the image later gets!
Same issue when using WinDVR and PowerVCR softwares.
The ONLY fast mpeg capture software I know which does support a good quality on HIGH avg Bitrates like at 8000-10000kbit is MCE and its capture engine. But also there you need a very fast CPU that realtime capturing/encoding using 704x576 i.e. is possible.
I would highly recommend in your case to swtch to picVideo mjpeg codec using a quality index of 19 and fieldbased recording. Its fast and lets you be able to capture 704x576(480) at a moderate speed/CPU power index.
Best but large! filesizes gives you the HuffYUV codec, its free and lossless.
The more your source is already compressed the more difficult is to obtain a well encoded kvcd spec. based final stream.
Inc.
KeepVID - Download videos DIRECT from most video sites kwag Computers 3 10-21-2006 02:37 PM
FastStone Capture - Very good Free Capture Tool sparskter Computers 0 08-28-2006 01:14 PM
DVD Burner: DVD+RW Direct On-disc Editing Hydeus Blank Media / Burning Discs 1 10-12-2004 03:30 AM
Recording Video: Direct DVD editing ? noize Video Capturing / Recording 4 02-11-2003 03:52 PM
Has anyone ever captured direct to KVCD? digitalvideo Video Capturing / Recording 1 06-20-2002 05:29 PM
All times are GMT -5. The time now is 07:49 PM  —  vBulletin © Jelsoft Enterprises Ltd
