Quantcast PS2 for VCDs? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Hardware and Technology Forums > Players, DVRs, Media Centers
07-20-2003, 10:59 PM
ijustbunkeredyou ijustbunkeredyou is offline
i was wondering if any1 knew if ps2 is a useable dvd player for vcds
<leet emocation
Site Staff / Ad Manager
07-21-2003, 03:29 AM
kwag kwag is offline
Hi ijustbunkeredyou, and welcome to the forum
I don't think the PS2 plays VCDs. Only DVDs.
-kwag
07-21-2003, 01:07 PM
ak47 ak47 is offline
I know PS2 doesn't play any type of CD's that are not music or retail game. But I do know that you can get it moded and find a program that allows you to play them which you might find at http://www.consolevision.com but the main reason I didn't get my ps2 moded because there is not no-solder no-swamp ones and also ps2 doesn't have many good freeware software(aka emulators, utilities, and homebrewed games). Also if you don't want to get your ps2 moded you can look at http://www.broadq.com/ its not free and it's kind of stupid since you have to run your movies though a Cat 5 cable(LAN cable). But instead I would recommend just getting a cheap DVD-player that can do, and will be just the same money and less time.
07-21-2003, 03:07 PM
thanks guys
09-14-2003, 04:39 PM
digisam digisam is offline
The PS2 does play DVDR and DVDRW burnt on my Mac
it doesnt play VCD or any CDR/CDRW media though
Why not have DVD style menus in VCDs? PyRoMaNiA Authoring VCD, DVD, Blu-ray 18 09-26-2004 08:42 AM
how to put my movies on vCDs? kornylak Video Encoding and Conversion 11 06-10-2003 09:44 AM
KVCD: Multiple VCDs on one DVD-R? niners Video Encoding and Conversion 10 06-01-2003 06:30 PM
my dvd player only plays vcds? venom_217 Players, DVRs, Media Centers 1 05-08-2003 02:01 AM
Using Svcd2dvd to convert 4 VCDs to DVD? dreamhost Video Encoding and Conversion 7 01-31-2003 01:43 PM
All times are GMT -5. The time now is 10:30 AM  —  vBulletin © Jelsoft Enterprises Ltd
