Quantcast Headac3he: Erase Voice from Song? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Audio Conversion
07-24-2003, 04:16 AM
schnitzel79 schnitzel79 is offline
Hi !
I didn't know where to put it, so please excuse me.
Is there a program that erases the singing part of a .wav file,
so you can use it for karaoke ?
I'm not so skilled so I would prefer a click-cklick-click-done program.
Site Staff / Ad Manager
07-24-2003, 04:31 AM
Dialhot Dialhot is offline
I guess that Goldwave or CoolEditPro both have a such filter (probably called "Cut voice").
07-24-2003, 05:20 AM
jorel jorel is offline
try AnalogX Vocal Remover - free
Allows you remove the vocals from most music!
Uses the same algorithm that the hardware Karaoke
machines use (180 degree phase offset).
Great for hearing the music more clearly as well as ripping samples!
Compatible with any realtime or non-realtime DirectX application
(like Cakewalk, WaveLab, Paris, CoolEdit, Sound Forge, etc).
see WinAmp Vocal Remover too.
homepage with tons of good free progs:
http://www.analogx.com/welcome.htm
direct to vocal remover:
http://www.analogx.com/contents/down...o/vremover.htm
my little hint:
when the voice is in both channel you can got a good result,
loosing some basses and listen some reverberations (aceptable) but
when the voice is in only one channel(means only in right or left channel),
all programs that i know can't do a perfect job removing the voice!
07-24-2003, 10:19 AM
Thanks a lot. Winamp voice remover works just fine.
Olympus W-10 Digital Voice Recorder for USB? LeeKuid Computers 0 11-15-2005 06:44 PM
KVCD: Multiplexing? gap between the voice and the sound? kvcdexplorer Video Encoding and Conversion 10 06-29-2005 05:57 PM
Blank Discs: Quick mode vs. Full mode to erase on a CD-RW?? LeeKuid Blank Media / Burning Discs 13 02-07-2005 06:00 AM
TeamSpeak - Multi user voice chat. kwag Computers 19 05-20-2004 03:38 PM
Creating voice chat messaging black prince Computers 1 02-06-2004 04:54 PM
All times are GMT -5. The time now is 04:00 AM  —  vBulletin © Jelsoft Enterprises Ltd
