Welcome
pothole,
I'd also recommend doing what
Dano said...read some of the useful How-To Guides listed on the right hand side of the main
www.kvcd.net homepage. If you want to do things the proper "kvcd way" (aka, the
right way!
) and end up with good results, then there's a bit more to the process than simply downloading a tmpg template and plugging in your source file. Take a look at Red-M's "KVCD From Scratch" Guide to familiarize yourself with the kvcd process...it's really not as difficult as it may first seem. And then read, read & read some more in the forums here...and then ask around if you've still got questions and someone will be happy to help you out. Pretty soon, you'll be showing off your KVCD collection.
Good luck,
-d&c
