Quantcast Cerco Template (o Istruzioni) per CCE - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Video Encoding and Conversion > Convertire e Codifica dei Video (Italiano)
08-29-2003, 02:29 AM
mikcek mikcek is offline
salve, qualcuno sa dirmi come poter fare dei template o scaricarli per CCE? visto che è molto piu veloce di tmpgenc!
aiutatemi grazie...
Site Staff / Ad Manager
08-29-2003, 03:32 AM
Dialhot Dialhot is offline
No so si parlai inglese, pero :
http://www.kvcd.net/forum/viewtopic....er=asc&start=0
09-01-2003, 08:14 AM
Thanks,
I speak english, I make my template for cce, following the guide, but I've just an other problem.
the output file from cce (.mpv) seems to be a bad file,
I can't open it with bbmpeg (or other prog as windows media player) for muxing with the audio.
if I encode with cce as mpg1 it works, but if try to encode as mpg2 it doesn't work.
I'm usin winXP
how canI fix this problem?
grazie
KVCD: Which template would be the best template to use? Fistandantilus Video Encoding and Conversion 4 08-30-2003 05:13 AM
Use the KVCDx2 template? or KVCDx3 template changed to 704x480? audi2honda Video Encoding and Conversion 1 08-26-2003 11:28 PM
kvcd: difference between the lbr template and the 352x240 template? bigggt Video Encoding and Conversion 6 05-02-2003 12:04 AM
KVCD: Plus template ok, x3 template not? Daznic Video Encoding and Conversion 1 08-30-2002 10:36 AM
default tmpgenc template or the skvcd template? andybno1 Video Encoding and Conversion 4 08-23-2002 12:24 PM
All times are GMT -5. The time now is 05:44 PM  —  vBulletin © Jelsoft Enterprises Ltd
