Quantcast Norcent DP-312 and Apex AD 1225? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Hardware and Technology Forums > Players, DVRs, Media Centers
09-11-2003, 01:52 PM
incognito incognito is offline
Anyone have stats on these players? Both are on sale at Walmart now for under $40. I tried a search for these players but came up empty handed. Thanks.
__________________
I own a Philips DVD 701. NTSC.
Site Staff / Ad Manager
09-29-2003, 10:20 AM
el_mero_zooter el_mero_zooter is offline
Send a message via MSN to el_mero_zooter
i picked up a spare ad-1225 and it played everything
vcd, svcd in ntsc or pal, dvd-r, dvd, mp3 etc...
except for KVCD. bummer,,,
was only $ 60.00 cdn though....
ztr
04-16-2004, 11:42 PM
tlaw007 tlaw007 is offline
Send a message via AIM to tlaw007
So far I am un successfull at playing KVCD's at a resolution of 240x480 however I am able to view KVCD's on this player using this template http://www.kvcd.net/KVCDx2-CQ-704x48...Film_-PLUS.mcf using a resolution of 704x480
Also It will play any SVCD encoded with this template
http://www.kvcd.net/SKVCD-352x480-_NTSC_.mcf
If anyone else has different results please let me know.
04-16-2004, 11:46 PM
kwag kwag is offline
And where did you pick out that resolution
-kwag
06-13-2004, 12:52 AM
Yourmove Yourmove is offline
to which player do you refer?
<EDIT> http://www.kvcd.net/SKVCD-352x480-_NTSC_.mcf worked for my APEX 1225 as for the other one i wasnt able to get it to work but it may be my encoding newbness
oh yeah...i'm pretty sure that KVCDs do not work at all on AD1225 :/...i've tried it many times and to no avail...skvcds seem to work if the resolutions are right
06-19-2004, 05:18 AM
w0000t
aight...i was able to find another skvcd template that worked with Apex AD1225
what i did was edited the tmpegenc template at http://www.kvcd.net/SKVCD-352x480-_NTSC_.mcf to have a resolution of 480x480 and it worked fine...the movie was a lil glitchy but think that was the sources fault
el_mero_zooter: you might wanna check me on this one tho :/ i am new to this and all
__________________
own a Apex AD-1225 and Apex AD-1500(Broken)
KVCD on Norcent dp 311 bigggt Players, DVRs, Media Centers 2 10-19-2003 01:04 PM
Info on the Norcent DP302V Sepheris Players, DVRs, Media Centers 0 09-14-2003 11:03 PM
KVCD on Norcent dp300 digitalvideo Players, DVRs, Media Centers 11 04-27-2003 01:52 PM
Norcent DP201 help christopher Players, DVRs, Media Centers 0 07-01-2002 01:56 PM
Apex AD-500w PlaiBoi Players, DVRs, Media Centers 0 06-18-2002 09:13 PM
All times are GMT -5. The time now is 06:00 PM  —  vBulletin © Jelsoft Enterprises Ltd
