Quantcast Authoring: DVD Ep Format? Extended Play Options? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Authoring VCD, DVD, Blu-ray
10-14-2003, 09:40 AM
ezysk ezysk is offline
Does anyone know anything about this so called "DVD EP FORMAT"...or the extended play option, that is the ability to record 240 mins on a DVD R media. Just wanted to know if you have to "tweak" something on your burner software to get this option.
Site Staff / Ad Manager
10-14-2003, 12:02 PM
kwag kwag is offline
Not sure what DVD EP FORMAT is ( (E)xtended (P)lay ), but I know for sure that with KDVD we already can get 6 hours at full D-1 on one DVD
-kwag
10-14-2003, 12:27 PM
....I only have a simple question: Just what are the average encoding times for a typical 2 hr widescreen movie using the FULL D-1 704x480 templates ???
10-14-2003, 01:54 PM
It all depends on what processor and speed you have. So it will be different for every machine.
-kwag
10-14-2003, 02:24 PM
....yeah, well, that's why I could use a DVD compatible 544x480 template.
10-14-2003, 06:31 PM
There is no 544x480 DVD compatible template (resolution), because 544x480 is not DVD compliant
However, you can encode 528x480 or 544x480 MPEG-2 and then use DVDPatcher to "patch" the mpeg header to 720x480, and author it and try it on a DVD(+-)RW and test it on your player.
It will play on most players, but not all.
If you want 100% DVD compliance, then encode 352x240, 352x480, 704x480 or 720x480 which are the suported DVD resolutions.
-kwag
how to make any format of film fit onto a CD-R and play on my DVD player? Frosty Video Encoding and Conversion 8 02-23-2006 04:46 PM
Authoring: Play All button with dvd lab pro bigggt Authoring VCD, DVD, Blu-ray 3 07-22-2005 03:03 AM
Which authoring program to Put 16:9 and 4:3 format on same DVD? zagor Authoring VCD, DVD, Blu-ray 4 07-14-2004 09:11 AM
Authoring: DVD Lab and Play All option Zyphon Authoring VCD, DVD, Blu-ray 7 03-30-2004 10:16 AM
Good software for DVD Authoring options? machfive Authoring VCD, DVD, Blu-ray 1 12-22-2003 04:54 AM
All times are GMT -5. The time now is 04:17 PM  —  vBulletin © Jelsoft Enterprises Ltd
