Quantcast Why does Creating a CUE/BIN File Increase File Size by 100mb? - digitalFAQ.com Forums [Archives]
10-25-2003, 08:57 AM
mistermickster mistermickster is offline
I have encoded my audio and video, muxed them together and have a final MPEG file of 803MB. No problem with overburn I thought.
But after adding the file to VCDEasy and starting to burn, the created cue/bin files end up over 100MB bigger at 924MB. Now even with overburn set I don't think that will fit on an 80min CDR.
Is there a way to burn a SVCD without first creating a cue/bin file, or do you have to take into account a poosible increase to file size when choosing the correct CQ to encode in?
Help please, as I don't wish to re-encode if my original MPEG will fit.
Thnx
__________________
MisterMickster
Site Staff / Ad Manager
10-25-2003, 09:11 AM
Dialhot Dialhot is offline
The problem was when you muxed. How did you perform that ?
10-25-2003, 09:17 AM
Hi Phil,
I muxed using the standard mutiplex option of TMPGEnc, (not simple multiplex).
Cheers
__________________
MisterMickster
10-25-2003, 09:41 AM
So you probably forgot to set the muxing mode to VCD(non standard) or SuperVideoCD AFTER you have load the source.
10-25-2003, 09:51 AM
That may be it.
I've generally set that BEFORE adding the source files.
Would that really make the difference
__________________
MisterMickster
10-25-2003, 10:15 AM
Yes it does : when you load the source, TMPEGenc automatically changes the mode to what it thinks the source is. So if you set "VCD(non standard) and load the file "video.m1v", the mode is changed into "MPEG1 (system)"
Mencoder: Mencoder and File Prediction to reduce file size ladiaz Video Encoding and Conversion 1 03-03-2004 12:20 PM
Mpeg Padding adds more than 100Mb to mpeg-2 file? Granny Authoring VCD, DVD, Blu-ray 13 11-26-2003 10:22 AM
way of creating a .d2v file from an .avi file? chimpus Video Encoding and Conversion 17 08-22-2003 06:49 AM
Encoding: Image file is increased by 100MB! alfredini Video Encoding and Conversion 2 01-17-2003 09:55 AM
Avisynth: File Size Predition vs Actual file size? Rig R. Mortis Avisynth Scripting 2 10-12-2002 06:04 PM
All times are GMT -5. The time now is 03:30 AM  —  vBulletin © Jelsoft Enterprises Ltd
