Quantcast Audio Codecs: WAV Codec? - digitalFAQ.com Forums [Archives]
11-26-2003, 07:49 PM
muhali3 muhali3 is offline
I have just convert a AC3 AVI file to WAV with virtualdub, and the sound won't play. RealOnePlayer says that it is in an unsupported audio format and i need the codec. what program can i use to scan the file, so i can see what codec i need?
i already have the AC3codec.
Site Staff / Ad Manager
11-27-2003, 04:35 AM
Dialhot Dialhot is offline
Never convert an ac3 with Vdub, it is nor it's job and it does it very poorly.
Just extract it using "Direct Stream Copy" and convert it with besweet or headac3che.
Note: in fact I'm quite sure you just extracted the audio but vdub always put "wav" as extension whatever the format of the audio. In fact you still have an ac3 stream that you should rename *.ac3.
Codecs: BEST CODEC to use? Wak10 Video Encoding and Conversion 2 09-25-2003 06:22 AM
Audio Codecs: Ac3 codec J-Wo Audio Conversion 4 09-19-2003 09:54 AM
Audio Codecs: YUV 4:2:2 Codec Jellygoose Audio Conversion 4 08-20-2003 05:40 AM
Audio Codecs: Best Audio Codec? Encoder Master Audio Conversion 7 08-15-2003 06:24 PM
Codecs: DXMan Video/Audio Codec Tool Bud Video Encoding and Conversion 1 08-13-2003 02:50 PM
All times are GMT -5. The time now is 07:43 PM  —  vBulletin © Jelsoft Enterprises Ltd
