Quantcast How to use Besweet to Convert PAL AC3 to NTSC AC3 - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Audio Conversion
12-13-2003, 02:20 PM
Icarus3000 Icarus3000 is offline
I have been told that the best tool to use for framerate conversion is BeSweet.
I downloaded the latest beta GUI and beta BeSweet files (0.7b1 and 1.5b23 respectively).
When I try to run the wizard to perform this task, it fails, telling me :
Error 73: Unable to get ac3enc.dll interfaces
So I tried directly in the GUI without the wizard, for converting AC3 to AC3, only AC3 to WAV, AC3 to MP2, and AC3 to OGG.
I have been told I should do this, so I know it must be possible, but at the moment I am stuck! I know someone on KVCD should be able to help me.
Many thanks,
Icarus
Site Staff / Ad Manager
12-13-2003, 03:08 PM
Dialhot Dialhot is offline
Set the encoding mode to "payload" and if it does not work, convert your ac3 in 5 channels wav (converting from PAL to NTSC) and then start forml this to go back to ac3
12-15-2003, 09:46 AM
I think I found the answer.
AC3Machine lookis like a GUI for besweet specifically for AC3 to AC3 encoding.
http://dspguru.notrace.dk/AC3Machinev0.41.zip
I'm at work right now but will try it when I get home.
Cheers,
Icarus
BeSweet: Avi with ac3 51. NTSC to PAL glent2k3 Audio Conversion 0 08-02-2004 03:19 PM
BeSweet: Besweet crashes when trying to convert OGG files rs008f Audio Conversion 29 03-04-2004 02:54 PM
BeSweet: Pal to ntsc audio Jag Audio Conversion 5 01-09-2004 06:57 PM
KVCD: PAl to NTSC? have to convert them to NTSC before encoding? WhiteKnight54 Video Encoding and Conversion 2 12-18-2002 10:32 PM
KVCD: How to convert from NTSC 23.xxx to PAL or NTSC 29.xxx StevetheSwede Video Encoding and Conversion 0 09-18-2002 09:23 AM
All times are GMT -5. The time now is 01:38 AM  —  vBulletin © Jelsoft Enterprises Ltd
